How would this do for a quick spooling LS stock motor turbo?
SPfab Quick4AC, Spoolin Performance
I assume this manifold would live up to daily driving?
Garrett T3/TO4E 50 trim w/ Stage II turbine housing, Spoolin Performance
Man U FTW
Re: How would this do for a quick spooling LS stock motor turbo?
That's a good combination. I used to run an SLS shorty with a GT3255 (similar to a 50 trim) and it was a beast of a street setup. You'll enjoy it
Couldn't find much of anything on Spoolin's quick4 manifold but I found a few complaints of the turbo being mounted too low which lead to oil drainage issues. So I might rethink that part and go with a cast manifold or Spoolin's street ramhorn.
I do wonder if the 50 trim is a great street turbo that will support over 300whp and have fast spooling...why does everyone with a stock motor build go with a 57trim and a .63 AR?
Man U FTW
Because people are afraid of running "more than 8psi" or some arbitrary excuse like that. You'll have better overall response with the 50 trim and it wont limit your power goals at all. It should make ~400-420whp if pushed
Who is Mr Robot?
Of course you could always go with a similarly sized ball bearing turbo and have better response abd considerably better recovery between shifts if budget isn't an issue.
I ran a ramhorn and something similar to a t3 super 60 on a stock Ls. it was a really fun set up, and fairly responsive.
I got to doing some searches and came across this good thread.
https://honda-tech.com/forced-induct...video-1665480/
I'm looking for a highly responsive turbo setup.
Moderator
This I agree with completely. Even moreso with the GTX2863R. I love it on the non-vtec 1.8 litres. Its responsiveness on an uncanny level. Put the extra money THERE instead of some ridiculously large manifold.
Just barely over 300whp. Plus you have to go to a 5 bolt turbine downpipe for it to work.
I kinda wish I woud of went with a gtx28 .but my gt3255 turbo response well and it puts in work on the street
That's with any "mini-ram" style manifold. Not just Spoolin' performance. But then why go with a Kooks manifold? That just makes the entire "responsiveness" go down even further. Sure they look great, but completely unnecessary for the need. Stick with a tubular log manifold, as they can support more without the need a ford style 5 bolt turbine housing. They are also more compact to fit than the others.
So you are more on board for me going with something like this? SPfab Log Manifold, Spoolin Performance
And I will take your advice on the turbo (GTX2863R). If you love it on a non-vtec 1.8L then that is all I need to hear. Where is the best place to get one?
Moderator
You lost me on the "Kooks manifold". What is that?
The GTX2876R... well, just PM me and I'll point you in the right direction.
