S366 or s362 or other opinions
My build
Block:
Darton sleeved gsr 84.5
Bc625+ rods
Cp pistons upgraded wrist pins crown coated
Arp main and head studs
Ls crank
Head:
Victor x intake manifold
Skunk2 Pro1 cams
Golden eagle cam gears
Supertech valve springs and retainers and valves
Turbo kit
Go autoworks pro top mount kit t3
Tial 44mm wg
Tial 50mm blov
I'm stuck on what turbo to run my goals are 400 to 500 hp on pump and 600 to 750 on race and I'd still like a decent spool time because it will be street driven mostly and track on weekends and parked for winter. I'd also like to be able to get rebuild kits for it so I can do it my self any opinions is appreciated.
Block:
Bc625+ rods
Ls crank
Head:
Skunk2 Pro1 cams
Turbo kit
Tial 44mm wg
Tial 50mm blov
Re: S366 or s362 or other opinions
For your goals the s366 will flow 82lbs wich is enough for 800 HP and the 362 will flow 73lbs. So if your looking to get 750,on race gas I would go with the s366. Also, where are you getting a t3 housing that fits it?,I have the s366 and only found it in t4.
Moderator
Here's the link to choose from:Bullseye Power Turbine housing upgrades
