battery kill switch
Old Feb 17, 2015 | 08:50 AM
84Riceeater's Avatar
Icon2 battery kill switch
☆mods please move if needed☆ I've found the forced induction fourms helped me the most in the past. I have some searching and found different ways people have done this. Only to get confused.Whats not pictured is the 100 AMP fuse that will be inline. about 3-6 In from the battery. Sorry for the horrible art skills.*
Battery to alt*
Battery to 1 side of cutoff
Starter to other side of cutoff
Fuse/switchpanel to same side as starter on cutoff
I'm not sure what indicates a 4 post cut off with a relay or the 2 post moroso style? What makes one better than the other i have a feeling I'm over thinking this. What's your take?
Old Feb 17, 2015 | 08:57 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: battery kill switch
in order to ill the entire electrical system, you need a cutoff switch that also kills the alternator field, if the alternator isn't cut there will be a huge voltage spike when the battery is disconnected, plus it will continue to feed current into the system
Old Feb 17, 2015 | 09:28 AM
Do you feel this would still power the alternator? i have a direct line from the alrernator to the battery. i would think it would kill power. But then agian im not sure.
Pumpking.
Jun 27, 2015 10:17 AM
ZCHondaCRX91
Oct 5, 2011 03:19 PM
Greg H
Jul 13, 2008 04:01 PM
Hondasaurs
Aug 28, 2003 08:26 AM
turbo sol
Apr 14, 2003 10:48 AM
