High Comp Turbo Build
Old Mar 20, 2015 | 10:41 PM
myownworstenemy's Avatar
Default High Comp Turbo Build
So I'm in the process of building my engine. It's a B18A1 thats been sleeved out to 84mm by Benson. Stock crankshaft has been polished and I'm running ACL race bearings.Its going to be a DD as well as some track days. I want high compression and a moderate-high amount of boost. I'm curious if anyone would know what would be a good comp ratio/lbs of boost. The correct internals to run with this setup. Clearances for bearings etc. Or if I'm just asking for a blown engine. Any help would be great. thnx
Old Mar 21, 2015 | 01:44 AM
Xanthias's Avatar
Default Re: High Comp Turbo Build
Use the FAQ's linked in the stickies above. Set a power goal and choose parts accordingly, psi doesn't matter different turbos provide different benefits. Goodluck
Old Mar 21, 2015 | 03:54 AM
sps2112's Avatar
https://honda-tech.com/forced-induct...build-3086196/
Check out muckmans build so much info there.
Old Mar 21, 2015 | 10:46 AM
Thanks guys
rfiand
Jan 27, 2014 08:00 PM
CRX SIR
Jun 5, 2007 02:44 AM
strepto
Sep 3, 2003 06:21 AM
S13 slide
Jul 30, 2003 03:36 AM
DualKnuttz
Mar 14, 2003 06:52 AM
