Hood stack or normal exhaust
Old Jan 28, 2015 | 10:21 PM
Civic420life's Avatar
Default Hood stack or normal exhaust
Im about to turbo my jdm built b16a with gsr tranny. I'm going for 500 hp and I'm gonna do everything to get to it. I would like to know if I could make more hp with 2.5" pipe coming from the turbo coming out the passenger side of the hood or the fender or use the normal exhaust going out the back. Numbers and dyno graphs would help if you possibly have any.
Old Jan 29, 2015 | 05:54 AM
Schister66's Avatar
Man U FTW
Default Re: Hood stack or normal exhaust
A hood or fender dump is going to get you pulled over every 10 minutes. For your goals, it will make a marginal improvement in power at best. If you've ever run an open downpipe car, you know that its not pleasant. I dont know why anyone would do this to any car that isn't a dedicated drag car...
Run it out the back - 3" with a muffler
Old Jan 29, 2015 | 12:25 PM
What about the waste gate.. Open or a dump tube
Old Jan 29, 2015 | 12:53 PM
KevinEF7's Avatar
You definetely need a dumptube, you dont want to dump it in the engine bay, you also make alot more power dumping it to atmosphere (outside the engine bay) vs routing it back into the exhaust.
I vote hood exit downpipe and dumptube
Old Feb 6, 2015 | 04:30 PM
And do I honestly need to use aluminum piping for the inter cooler? I feel like I could just use lightweight steel pipe and very few couplers
Old Feb 6, 2015 | 04:42 PM
DA-NINE's Avatar
How do you plan on dealing with the corrosion inside the charge pipes if you use steel charge pipe.
Old Feb 6, 2015 | 05:18 PM
TheShodan's Avatar
Moderator
Great rebuttal question.
Old Feb 6, 2015 | 06:12 PM
Turbo-LS's Avatar
Stainless works. I used aluminized in the past and that worked. It's heavy and aluminum is better anyway.
Just make a downpipe 3" with exhaust or open DP if you wanna smell the fumes all the time. Can also utilize vbands to easy removal of a section of pipe off the downpipe for track says etc
I've had an uppipe on my car a while and I just had to make a downpipe for it for class rules and honestly I like it. It's louder and the engine sounds better deeper with the longer pipe Vs out of the hood.
Old Feb 6, 2015 | 08:23 PM
wantboost's Avatar
Who is Mr Robot?
Also remember that aluminum conducts heat much better than any steel alloy. So to some extent the heat generated from the turbo compressing air will be lost to the atmosphere through the piping as well as the intercooler.
Old Feb 6, 2015 | 08:33 PM
TheShodan's Avatar
Moderator
Originally Posted by wantboost
Also remember that aluminum dissipates heat much better than any steel alloy. So to some extent the heat generated from the turbo compressing air will be lost to the atmosphere through the piping as well as the intercooler.
Fixed for ya..
Old Feb 7, 2015 | 12:27 AM
wantboost's Avatar
Who is Mr Robot?
I'm tired lol.
The other problem with a hood exit on a street car is if you're tuned rich you'll end up blowing this black carbon **** on your hood, trunk, windshield, and roof. It's damaging to paint and will eventually strain everything it touches.
Old Feb 7, 2015 | 05:02 AM
Turbo-LS's Avatar
Then said person needs a new tuner lol
Old Feb 7, 2015 | 12:34 PM
wantboost's Avatar
Who is Mr Robot?
Not every tuner is great lol
Old Feb 10, 2015 | 11:39 PM
My dude is pretty good he's 20 years in the game. He's built a 1200hp integra and could of broke the 1400hp mark with nitrous. But back to the exhaust.. I just want something that's gonna sound good and not super raspy but get the best flow. I really wanna do a sleeper build that's why I want it to sound nasty as hell but not scream im boosted and save it for whoever wants to race.
Old Feb 11, 2015 | 04:04 AM
hardcore97's Avatar
If you want it to be both subtle but also sound mean my vote would be a normal exhaust with a decent muffler for when you want to be quieter, then an e cutout for when you want to open it up and sound mean. I have an e cut out that's pretty much just open downpipe when open.
Old Feb 11, 2015 | 05:20 AM
LightningTeg's Avatar
Community Builder
I have had steel pipes on my car for many years. No sign of corrosion or rust. They are def. heavier then aluminum, but I was able to make/modify them myself with a mig welder.
Old Feb 11, 2015 | 07:10 PM
GoldieWang's Avatar
10 Year Member
I feel an uppipe out the hood would only make a small noticable difference in spool time, and maybe a couple ponnies. But all I have ever had was a 3 inch turbo back system with the dump ran back into the down pipe. (It had no problem with spooling my precision 5858)
jamesc182
Jul 29, 2013 08:48 AM
crazes
Aug 15, 2012 12:43 PM
c5R
Welding / Fabrication
Dec 12, 2010 03:20 PM
pjr710
Sep 24, 2008 08:00 AM
nd8ch
69
Feb 26, 2003 01:13 PM
