Rich/ Lean Issues on a FI LS
Old Aug 31, 2001 | 05:45 AM
revhrdls's Avatar
Default Rich/ Lean Issues on a FI LS
as of now my rev hard II kit has stock injectors, but no inline or intank performance fuel pump. I don't know how it's running now, but if I add just the pump would that be sufficient to have it run as stoich as possible, or would i need to add 310s. The problem is that I don't want to run too rich, because come smog time I can pass it easier then having to tear it all out...
David
Old Aug 31, 2001 | 06:08 AM
b18bturbo's Avatar
Default Re: Rich/ Lean Issues on a FI LS (revhrdls)
you need to get inline pump or huge intank pump that can handle high psi pressures. Right now your car is probably running extremely lean. The LS can take 7-9 psi on stock injectors before it will start to run lean. 10-12psi is possible on stock block if you get 370cc and fuel controller.
Old Aug 31, 2001 | 06:33 AM
GSRwBOOST's Avatar
Default Re: Rich/ Lean Issues on a FI LS (b18bturbo)
I had the same problem.. only i had an upgraded 255 intank pump, it would run lean anyway.. Mark let me know one day that I need the inline pump because even though the pressure is high, it's the flow that's not getting into the fuel rail/injectors... an inline pump will help you a good bit... i'm nt runing lean anymore under boost....
Old Aug 31, 2001 | 08:00 AM
revhrdls's Avatar
Default Stock injectors Max flow
At what point do stock injectors reach their limit of flow, say max 6-7 psi of boost or so with the help of an inline of course...
David
Old Aug 31, 2001 | 08:12 AM
TurboInteg95's Avatar
Default Re: Stock injectors Max flow (revhrdls)
YOU ARE RUNNING LEAN. you need to get an inline Bosch pump or at least a high pressure intank pump. Dont even try to boost it without a fuel pump. I wouldnt boost over 8 psi with the stock injectors.
honda9369
Oct 11, 2004 02:56 PM
rjardy
Oct 14, 2002 08:15 AM
DJ0820
Aug 1, 2002 11:56 AM
Smoothy
Oct 6, 2001 06:48 AM
