Need some help on my T25
Old Sep 4, 2001 | 12:01 PM
jmad08's Avatar
New User
Default Need some help on my T25
i pieced together a custom T25 on my 00' civic but the stock boost on the acuator is 10psi. i want to know if there's a actuator that i can bolt up to it to just maintain 6psi. please help me out. thanks
Old Sep 4, 2001 | 12:04 PM
Rob03Pro5's Avatar
Default Re: Need some help on my T25 (jmad08)
Why dont you remove that actuator and use an external wastegate? It's simple unless your manifold has to be modded to fit an external wastegate.
Old Sep 4, 2001 | 02:11 PM
LudeSi-93's Avatar
New User
hmm... what you might be able to do is to modify the spring that is in the actuator right now. With a stiffer spring, it'll open later thus more boost. With a lighter spring, it'll open soon, less boost.
Old Sep 5, 2001 | 02:49 PM
integRated109's Avatar
Default Re: Need some help on my T25 (Rob92SC)
my friend is putting my old deltagate on his 16G, turbonetics sends all the measurements to make the flange with the w/g
Old Sep 5, 2001 | 02:58 PM
93LSivic's Avatar
You can thread the actuator arm. When you do this, you will basically have an "adjustable boost controller"
This is the one from the saab turbo that I am retrofitting to my project
Actually I lucked out, this turbo came with the threaded arm!
[Modified by 93LSivic, 6:59 PM 9/5/2001]
allsho
Feb 6, 2007 12:42 AM
WH0R3nEF9
Sep 28, 2005 07:13 PM
oMek
Feb 29, 2004 09:09 PM
whiteblurr
Dec 31, 2003 09:17 PM
92SiB18C1
Nov 30, 2002 06:34 AM
