F-in vtec code is pissin me off, need help please
Old Sep 4, 2001 | 12:19 PM
boost killz's Avatar
New User
Default F-in vtec code is pissin me off, need help please
Ok here's the problem. When I start the car I get a code 22 which results to me bogging if I go into vtec. So far I have checked all resistances and voltages and they checked in clear, I replaced spool valve filter and also o-ring gasket between solenoid and vtec assembly, also checked for free play on pillar inside assembly and all was well. The deal is when I shut the car back down after heating it up reset the ECU and the code was gone and will usually only come back when the car is cold again. Have any of you seen this or may know what my problem is.. 115 bucks for a new solenoid from the dealer is fine but I don't want to waste the cash if it isn't necessary as opposed for 25 bucks for a new pressure switch.. Any clues amigos? Thanks in advance,
Nick
Old Sep 4, 2001 | 02:28 PM
Jared's Avatar
Default Re: F-in vtec code is pissin me off, need help please (boost killz)
check your oil level and oil pressure
Old Sep 4, 2001 | 02:48 PM
Turbo00's Avatar
New User
Default Re: F-in vtec code is pissin me off, need help please (Jared)
do you have a VAFC? if so those connectors that they give you are pretty crappy. i used to throw code 22 all the time then i sodered(dont know how to spell) it. and that got rid of the problem
Old Sep 4, 2001 | 03:38 PM
G's Avatar
G
Is your turbo oil feed in the head area?
Old Sep 4, 2001 | 04:09 PM
New User
Default Re: F-in vtec code is pissin me off, need help please (G)
Oil pressure I have yet to check, oil level is good and no feed line is running around but not close at all...this sucks
Old Sep 7, 2001 | 06:00 PM
speedworks's Avatar
customer of mine had simular problem.checked everything at least 4 times.
ended up being the oil pan. he had hit something and it had pushed the bottom of the pan into the pick-up but still had oil pressure until it went into v-tec and could
not get the volume of oil needed to lock rocker arms together. just something
to think about.
Old Sep 7, 2001 | 07:01 PM
smkngsr's Avatar
does it matter if its on the head...if it is on the head where will it be if its in the head...mine is in the bottom of the manifold...thanks million
wrx'n you
Feb 3, 2007 01:07 AM
over_
Dec 2, 2006 03:55 PM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
JKim0901
May 8, 2003 12:41 AM
boost killz
Sep 5, 2001 06:30 PM
