ls turbo questions
Old Aug 29, 2001 | 10:14 AM
SlowPoke's Avatar
New User
Default ls turbo questions
Well i wanna know about turbo on a 97 ls, stock engine
I first plan on lowering the cr with thick headgasket
Next I plan on using 5-7psi daily but 10(maybe little more in the future) for racing
My friend told me all I need is to do the thick head gasket to lower the compression and get 310 or 370cc injectors and I will be able to boost up to 10psi safely. How true is this?? Will I need anything else?
thanks
Old Aug 29, 2001 | 10:20 AM
TurboInteg95's Avatar
Default Re: ls turbo questions (SlowPoke)
you dont need to lower compression. I run 10 psi all the time on my stock LS motor with 310's and an 8:1 disk in my FMU.
Old Aug 29, 2001 | 10:41 AM
b18bturbo's Avatar
Default Re: ls turbo questions (TurboInteg95)
no need to lower compression i used to run 12psi stock motor never blew just get a little larger injectors and control them some how.
Old Aug 29, 2001 | 11:18 AM
SlowPoke's Avatar
New User
Default Re: ls turbo questions (b18bturbo)
ok so if i get larger injectors, what else will I need, if I get 370cc will my idle be crap? will 310 handle 10psi? will I need to get a fmu(what is it?) or a new fuel pump?
Old Aug 29, 2001 | 11:39 AM
DIRep972's Avatar
Smarter than you
i plan on running 13psi on my stock motor with a hondata and 550cc injectors.. u dont need to lower compression, just make sure u have enough fuel and that it is tuned right and u should be able to boost 10psi no problem..
Old Aug 29, 2001 | 11:45 AM
b18bturbo's Avatar
definitley need a new fuel pump highly reccommend bosch with 310cci njectors.
Lordofdark176
Nov 21, 2007 08:42 PM
doublejz
Aug 10, 2005 03:41 PM
b1893hatch
Jan 7, 2004 09:35 AM
SlowPoke
Aug 29, 2001 03:00 PM
