oil line for turbo
Old Sep 7, 2001 | 07:09 PM
smkngsr's Avatar
Default oil line for turbo
My oil is leakin from the block but its not that bad..i was wondering if that is really bad for the turbo...i dont wanna tighten it to tight because im affraid that im gonna stripped the thread...what should i do with this..if its not that bad for the turbo i would not mind at all...thanks a million in advance
Old Sep 7, 2001 | 07:12 PM
smkngsr's Avatar
Default Re: oil line for turbo (smkngsr)
actually it was leaking in the block from the oil pressure switch...
Old Sep 7, 2001 | 07:56 PM
turbo_b18c's Avatar
you should take out the whole tee and buy new tee and adapter. when you put the fittings back on you should apply a fair amount of teflon tape. doing this would save your turbo and many headaches. good luck
Old Sep 8, 2001 | 08:01 AM
smkngsr's Avatar
Default Re: oil line for turbo (turbo_b18c)
thanks ur tha man...
Old Sep 8, 2001 | 09:56 AM
stizzit's Avatar
or you could do it the right way and buy a BSPT adaptor fitting instead of an NPT - the fitting you're using it close but it's one thread off. Good luck
ÁrniMkv
Feb 10, 2012 07:02 AM
chrisbell37
Feb 3, 2006 06:36 AM
jdm2ner
May 15, 2005 12:52 AM
slo_crx
Oct 12, 2004 05:51 PM
1.8EG-T
Jan 3, 2002 11:47 AM
