map check valve problem
Old Aug 29, 2001 | 12:52 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default map check valve problem
this is on a '93 prelude with a rebuilt j-spec f22 with a custom t3 setup...this friend's install and build was done by some guys who apparently ghettoed his car bad. they did not have any kind of fuel management. they did have an inline pump and oh yeah, there was a piece of wire crimped around the fuel return line (custom ghetto fmu!) haha, i could not believe that. and the injectors are stock.
we took off the wire thingy and put a fmu for the moment.
since he has been boosting, he has been getting c.e.l. and bad throttle response. of course, there were no check valves of any sort. thinking that a missing link would solve the problem, he bought one and we put it on and it took the check engine light off but now it runs even worse and a **** ton of black smoke comes out his exhaust. as of now, there is no missing link connected because it made things worse??? could it be a bad check valve (it's new)? or how else can you bypass the boost from the map sensor?
Old Aug 29, 2001 | 01:15 PM
bgod's Avatar
Default Re: map check valve problem (ho focker)
you have to check to see what codes your friend is getting.
Old Aug 29, 2001 | 01:19 PM
Jared's Avatar
sounds like you were having a map sensor problem, the missing link fixed it, and then with a properly working map sensor you were running waaaaaay too rich.
Civiclx
12
Jul 26, 2004 02:06 PM
kook911
Jul 7, 2004 11:39 AM
ejectseat
Jan 27, 2003 02:09 PM
CiViC SiR
Dec 29, 2002 07:31 AM
97GSRT
Mar 29, 2002 04:34 PM
