When is the fuel pump supposed to turn on???
Old Sep 2, 2001 | 06:09 PM
Smoothy's Avatar
Default When is the fuel pump supposed to turn on???
I always thought it would go on before cranking to build pressure. I had the pumped hooked up a long time ago by someone else. I find that it only turns on when I crank. I don't know if it stays on when the engine is on because I can't get it to start. But so far its only on when I crank the engine. It that how it should be?
Old Sep 2, 2001 | 09:04 PM
TurboInteg95's Avatar
Default Re: When is the fuel pump supposed to turn on??? (superfastCRX)
I always hook my pumps up to the stock relay, if you're still running an intank pump as well then use the stock relay to trigger another relay for the inline pump.
Old Sep 3, 2001 | 05:42 AM
QuickHonda's Avatar
it should turn on for a couple seconds when you turn the key to the accessory spot however since fuel pressure is held in the line it sometimes may not start up since there is already snough pressure in the line.
Scotty_1988crxsi
Feb 18, 2009 07:33 PM
B16A CRX
May 28, 2008 04:57 PM
iNDyCRX
Apr 24, 2008 12:54 PM
Mag00n
Dec 20, 2006 12:44 PM
redlshatch
Jan 29, 2006 06:38 PM
