THERMAL QUESTION!!!! need help quick!
Old Aug 30, 2001 | 01:18 PM
Mr. Vapor's Avatar
Default THERMAL QUESTION!!!! need help quick!
Ok i got my thermal 3" today
it didnt come with directions or anything so i assume its a straight install, ok no problem. my question is however, will my thermal work with my Stock exhaust manifold and cat untill i get my turbo in, or do i have to wait for my turbo to install this?????
Old Aug 30, 2001 | 01:34 PM
Mr. Vapor's Avatar
Default Re: THERMAL QUESTION!!!! need help quick! (NYb16)
Ok i just called thermal, and they said that the 3" pipe will not port match to my cat, cause my cat is only 2.5"....they said i need to have a piece fabricated at my local mufflar shop, has anyone heard of this!! WHAT DO I DO!
and also excuse my newbiness, but with the Drag 3 turbo kit, is my cat replaced by my down tube or does the cat remain? please anyone!
Old Aug 30, 2001 | 01:47 PM
b18bvudoo's Avatar
New User
the downpipe is 2.5" and it does not replace your cat but is suppose to bolt up to it. So if you dont plan on replacing your cat then you'll have to go to the muffler shop to get a flange for your thermal 3"
Old Aug 30, 2001 | 02:04 PM
Mr. Vapor's Avatar
Default Re: THERMAL QUESTION!!!! need help quick! (vudoo666)
so you are saying the thermal is meant to bolt up to my stock cat?
Old Aug 30, 2001 | 02:39 PM
chri5's Avatar
NO.
Old Aug 30, 2001 | 03:46 PM
b18bvudoo's Avatar
New User
No. if you dont have the cash for a hi-flow cat then you'll need a muffler shop to make your current setup all work together.
Old Aug 30, 2001 | 04:11 PM
Ben Huynh's Avatar
Car Sound 3" Cat: $99.00
Once the turbo kit is installed, drive the car to your muffler shop and they will take over from there.
Old Aug 30, 2001 | 05:02 PM
Mr. Vapor's Avatar
Default Re: THERMAL QUESTION!!!! need help quick! (ben@importparts.com)
Do you guys reccommend a high flow cat or take my shop to the muffler shop and have them fabricate me a flange??
Old Aug 30, 2001 | 06:58 PM
b18bvudoo's Avatar
New User
I think you'll have to go to a muffler shop anyways 'cause I dont think the drag downpipe has a flange on it. As for the cat I think most FI guys on here do not recommend running a stock cat.
Old Aug 30, 2001 | 07:24 PM
Ray's Avatar
Ray
New User
actually most FI guys run test pipes
Old Aug 31, 2001 | 12:36 PM
Mr. Vapor's Avatar
Default Re: THERMAL QUESTION!!!! need help quick! (Ray)
So it whould go like this....
Downpipe - 2.5" to 3" flange - Highflow 3" cat or test pipe - Thermal 3" ehxuast, do i have this correct?
Somehow i need to get the downpipe to 3", which would be the purpose of the flange
Old Aug 31, 2001 | 01:57 PM
Ben Huynh's Avatar
Tim, you have it right.
Old Aug 31, 2001 | 04:32 PM
lucas569's Avatar
where do you buy a car-sound cat for $99?
Old Aug 31, 2001 | 04:37 PM
Ben Huynh's Avatar
Default Re: THERMAL QUESTION!!!! need help quick! (lucas569)
From importparts.com, where else?
Old Aug 31, 2001 | 04:40 PM
lucas569's Avatar
ben u have im...
Old Aug 31, 2001 | 10:12 PM
outlawtas's Avatar
New User
it may be a stupid question, but i'm just wondering what's the point in running a 3" exhaust with a only a 2.5" downpipe? and without a high flow cat? doesn't make any sense to me...
Old Aug 31, 2001 | 10:28 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: THERMAL QUESTION!!!! need help quick! (outlawtas)
Excuse me, thats whrer I come in. https://honda-tech.com/zerothread?id=58034
easyFOsheezy
Aug 26, 2010 02:03 PM
00supercivic
May 18, 2005 06:53 PM
LuderCriS
Mar 15, 2002 04:44 AM
Brian_92GSR
Dec 13, 2001 03:22 AM
