Hesitaion Problem at 35oo rpm's
New User
Anyone with a JRSC have hesitation problems between 3000 and 4000 rpm? My car hesitates and shows a lean condition for a second. This is with partial throttle. My atmospheric fuel pressure is at 65 psi and 52psi static. I have a Cartech 2005 and am running 10 psi.
Re: Hesitaion Problem at 35oo rpm's (ndmracing)
sounds like you are running a little lean are you using the stock injectors?? A lot of JRSC have the det. problem in that part of the Rpm.
Do you have anything else to tune fuel or timing??
New User
Re: Hesitaion Problem at 35oo rpm's (bgod)
All I have to monitor and control fuel are the A/F meter, Cartech FMU, and fuel pressure guage. I have the Walbro fuel pump that Jackson racing sells. Not sure exactly what it flows at. I'm guessing 225 lph. I've been messing with the Cartech for days now and nothing seems to help out. I pumped the atmos. press. to 70 psi and it seemed to help slightly...but it could be my imagination.
HybridCoupe
07-06-2002 03:48 PM
GSRwBOOST
07-19-2001 11:03 AM
