what turbo?
I have a 2000 integra gsr i would like something over or around to 300hp total more would be good too what is the best turbo kit for this goal and what all is needed to achieve this pistons, rods, injectors ect..........
I'm no autority on this, but most of the "big boy" turbo's (ala DRAG, RevHard, F-Max) kits for the B18C1 deliver in the neighborhood 300 flywheel hp with proper tuning. For the sake of longevity, I would definatley look into rods, pistons, re-sleeving the block and maybe a block guard or if you really wanna get into it, decking the block (though for 300hp this may be a little extremme).
Well, I should have said close-decking it, which of course refers to welding a plate ontop of the block thereby making it a "closed-deck" block as opposed to the natural open deck design of all Honda blocks. Much more rigidity for the cylinder walls making it Turbo friendly
Well I have 274hp to the wheels, 200ft/ lbs of torque = 315 horsepower to the crank @ 7.35psi.
My set up:
-Rev-hard turbo kit
-3" arturbo downpipe
-3" thermal exhaust
-Greddy profec A boost controller.
-Tial Wastegate
Thats it...
art
My set up:
-Rev-hard turbo kit
-3" thermal exhaust
-Tial Wastegate
Thats it...
art
Smarter than you
those both will produce about the same HP, some people like either kit for different reasons..
if u want 300 @ the crank thats easy as pie, but 300@ the wheels is a bit tougher..
u CAN do it on stock motor, u will need one of the above turbo kits, 3" exhaust system including DP, Skunk2 IM manifld w/ throttle body for GSR, 440cc injectors, standalone ECU, maybe some cam gears, and 10psi of boost and ALOT of tuning.. that set up should yeild 300whp or maybe more..
VTgringo
10
Jul 18, 2004 09:11 AM
