Turbo install help?????
Old Sep 1, 2001 | 04:27 PM
boosted12.9's Avatar
New User
Default Turbo install help?????
I have a 1998 integra gsr i installed a F-Max turo kit last week. I have a problem installing the little box to control the 2 injectors included in the kit. The kit came with a 3 bar map wich im not sure how to connect also. If any one has any information that would e help full to finish my install please let me know. Oh and also on the hks low off valve there are 2 outlets for a vacum line the top one goes to the manifold, so where does the side one go to.
Thank you
boosted12.9
Old Sep 1, 2001 | 06:00 PM
synthtk's Avatar
New User
Default Re: Turbo install help????? (boosted12.9)
check this for reference.. http://www.f-max.com/installpage.htm
also did your MF2 come with its instructions? I thought the instructions were pretty clear.. 2 wires from the MF2 harnes goto the injectors, three goto the map and the others i forget go where, to the Dist if i remember right.. anyway the instructions are good and most of the wires are color coded..
as far as the hks blow off.. i dunno about yours but mine has just 1 vacuum line in point... i think you mean the wastegate? that will have two ports.. read your boost controller documention for the hookup of that..
hope this helps a little
-Chris
cademan
May 9, 2004 06:17 PM
10seceg
Feb 23, 2004 06:22 PM
BurlyHatch
Nov 18, 2003 01:36 AM
5thgencivic
Mar 8, 2003 06:46 PM
ITRfaithful
Jun 30, 2002 12:37 PM
