BAR to Psi conversion??
Old Sep 7, 2001 | 07:04 AM
VTC_CiViC's Avatar
Default BAR to Psi conversion??
Since my AVC-R only reads in BAR and my autometer gauge in Psi, I'd like to know how to convert one to the other so I can see just how accurate my AVC-R and boost gauge are.
Old Sep 7, 2001 | 07:08 AM
Pritos's Avatar
New User
Default Re: BAR to Psi conversion?? (VTC_CiViC)
http://www.convert-me.com/en/
have fun!
BoM's Avatar
BoM
i think it was 1 bar equals 14.5 psi
Old Sep 7, 2001 | 07:10 AM
Rob03Pro5's Avatar
1 bar = 14.5 psi. Some people use 14.7psi.. but I think they're getting confused with atmospheric pressure. Just go by 1 bar = 14.5 psi and you'll be safe!
Old Sep 7, 2001 | 07:43 AM
VTC_CiViC's Avatar
Default Re: BAR to Psi conversion?? (Rob92SC)
Hmm that's odd then because I was set at .25 bar and I'd see 4-4.5psi on my boost gauge. Going by BAR=14.5psi, I should have been seeing 3.6psi. As a matter of fact, from 3-5700rpm I'd see about 4psi, but then from 5700 to the redline i'd run 3.5psi (.25 bar), and I remember reading in the manual adjusting the sol. Duty cycle to compenste for overshooting, guess this is what I'm expereincing right?
Old Sep 7, 2001 | 08:15 AM
Rob03Pro5's Avatar
What boost gauge do you have? If it's an Autometer, that could be why its off. Autometers are not very accurate.
Old Sep 7, 2001 | 08:31 AM
DIRep972's Avatar
Smarter than you
for every 1/10 in bar you can convert it to 1.47 psi.. or just say 1 bar=14.7psi
say .5 bar, you have 7.35psi, .6bar would 8.82psi, .7bar is 10.29psi and so on.. .25 bar would be 3.675psi
Old Sep 7, 2001 | 08:35 AM
VTC_CiViC's Avatar
Yea it's an autometer Sportcomp. When I hit the "peak" button on the AVC-R, it showed me a peak of .29BAR (set for .25), .29 equates to about 4.2psi, right on the money with what the autometer was showing me
Old Sep 7, 2001 | 09:43 AM
redline's Avatar
the Avc-r shows kg/cm2 which 1kg/cm2 = 14.22psi
Civiclx
Apr 12, 2004 07:19 AM
JdmVetteEater
Jun 17, 2003 10:02 AM
LS-T
Dec 13, 2001 06:32 AM
InfamousRS
Oct 30, 2001 03:28 PM
