Max boost
Old Sep 5, 2001 | 03:00 AM
Cyber ITR's Avatar
Default Max boost
hi what u guys reckon the max boost u can run in a standard internals B18C
consider if the fuel supply will be upgraded
Old Sep 5, 2001 | 06:24 AM
VTC_CiViC's Avatar
Default Re: Max boost (VTEC_SiR)
My best guess for a stock B18C bottom end would be around about 10-12psi? I know alot of guys on D16's pushing 8psi on stock bottom ends reliably for quite some time granted the D16 uses lower CR than B18C's do, so provided you have the right amount of fuel dialed in, I think 10 or a little more should hold up ok.
Old Sep 5, 2001 | 06:39 AM
bigTom's Avatar
Default Re: Max boost (VTC_CiViC)
i would say 10-12... BUT and i stress this... with the correct fuel management... ie; dfi, speedpro... etc.
Old Sep 5, 2001 | 06:45 AM
b18bturbo's Avatar
Default Re: Max boost (ek9t)
you can run around 20psi on stock gsr block with some form of computer such as haltech,dfi,speedpro,hondata. etc..
Old Sep 5, 2001 | 02:50 PM
Cyber ITR's Avatar
20psi ??? hmm i dont think im want to risk my engine cant afford for a new engine
so u guys reckon 10psi should be alright ???
one more think, i dont live in US and i like to know bout the misti eclipse , are they FWD or 4WD ?
thanks guys
Old Sep 5, 2001 | 03:00 PM
93LSivic's Avatar
How about on a stock LS, with fuel management but no stand-alone or any kind of computer like that??
Old Sep 5, 2001 | 04:11 PM
redline's Avatar
thanks guys
eclipse is can be FWD in a GS model, FWD turbo in a GST model and AWD turbo in a GSX model
And i run 10psi on my GSR (b18c1) with upgraded injectors (310cc) 8:1 FMU, Fuel pump, BTM and J&S
[Modified by redline, 6:13 PM 9/5/2001]
Old Sep 10, 2001 | 11:56 AM
IgniteTeg's Avatar
Default Re: Max boost (redline)
How about the gsr on stock internals and whatever the fuel stuff Drag III comes with at what psi would be good and safe for daily driven????? Thanks for any help.
Old Sep 10, 2001 | 12:07 PM
b18bturbo's Avatar
Default Re: Max boost (IgniteTeg)
stock internal and on a gsr 6-8psi with just the drag stuff. If you want more get larger injectors and Lower the fmu disc and add a fuel controller.
Old Sep 10, 2001 | 12:30 PM
boost killz's Avatar
New User
Default Re: Max boost (b18bturbo)
I myself will more than likely be going with about 12 psi on stock internals with my greddy kit but granted with a hondata stage 2b and the 440 injectors with Vaportrail hopefully next month if all goes wel financially for me. Basically Vapor as well as my good friend said the same thing with the correct fuel management and tuning 12 psi will not hurt the engine, it's the detonation. Laters
Old Sep 10, 2001 | 12:40 PM
FAST94GSR's Avatar
New User
Default Re: Max boost (boost killz)
Redline how much power you making?
Old Sep 10, 2001 | 12:55 PM
redline's Avatar
Default Re: Max boost (FAST94GSR)
Not enough!!!
I am parking my car soon and pulling the engine for a rebuild. It has never been to the dyno with the turbo and when i went to the track the clutch started to slip before i got one good pass in.
My best trap is 105 with a 2.5sec 60 foot and no power shifts this is all at 4000 feet above the sea which makes a BIG difference. Just so you have a frame of reference SS f-bodies run 98miles here and a new cobra runs about 95 miles. It is tough to make power here.
k
b18c_Ek101
Sep 2, 2010 05:52 AM
ABK
Engine Management and Tuning
Dec 20, 2008 11:49 AM
EGJDM
Apr 16, 2003 09:06 PM
gigantor
May 22, 2002 02:53 PM
