pressure flex question
Old Aug 30, 2001 | 05:17 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default pressure flex question
pressure flexing is when you rev a turbo and close the throttle and blow-off if you have one. how come some cars do it and some don't? i have a blow-off and i am boosting 8-10 psi and it works when i am only in gear, moving under load, and then close the throttle. if i just rev it high and close it, sounds like it's not even turbo??? i see that when i do that, the boost gauge will not go above 0. i know gst's can do this pressure flex and some other cars...i am just curious what makes this possible?
Old Aug 30, 2001 | 06:08 PM
dustin's Avatar
Default Re: pressure flex question (ho focker)
GSTs have such miniature turbos that they spool even when the motor is not under load. Our hondas use large T3/T4 hybrid turbos that do not spool unless the motor is under load.
Dustin
m00genwant2b
May 26, 2011 05:53 PM
importdude2000
Dec 9, 2008 03:27 PM
civickid03
Apr 12, 2007 11:27 AM
whp
Nov 11, 2004 06:35 PM
sdrawkcabssa
Mar 5, 2003 06:49 PM
