a/c and turbo`
Old Sep 6, 2001 | 05:19 PM
Integra187's Avatar
Default a/c and turbo`
does the drag III kit let u keep your ac?
Old Sep 6, 2001 | 05:33 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: a/c and turbo` (Integra187)
Yes.
Old Sep 6, 2001 | 08:35 PM
redline's Avatar
Default Re: a/c and turbo` (Arturbo)
I had to do some bending of the A/C lines. It is a tight fit with my turbo but everything is still there and working.
Old Sep 6, 2001 | 08:38 PM
MiraiZ's Avatar
Default Re: a/c and turbo` (redline)
memo...more drag tweaks...yum!
Old Sep 6, 2001 | 09:12 PM
quikrpm'z's Avatar
How does everyones ac work? Mines causes the engine to idle too low, almost kills the engines.
Old Sep 6, 2001 | 09:29 PM
integRated109's Avatar
Default Re: a/c and turbo` (quikrpm1)
mine does the same crap.......but its ok on the road. i never actually use it though, so im thinking of ripping it out.
Old Sep 6, 2001 | 09:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: a/c and turbo` (integRated109)
The AC lines you are talking about are the ones in front of the car. So even if you have Drag, Fmax, or rev-hard you still have to bend it for the intercooler to fit. This applies to Ingegras with any turbo kit, even Fmax..
art
Old Sep 6, 2001 | 10:11 PM
redline's Avatar
art
nope not mine... between the rad and engine. My turbo is freakishly huge. Bigger then any of the pics i have seen posted on the net. and caused some MINOR problems with mounting the turbo!
With the A/C on the idle should rise by 3-400 RPM if the idle drops and stalls the car there is another problem some where.
[Modified by redline, 12:13 AM 9/7/2001]
Old Sep 7, 2001 | 12:48 AM
dustin's Avatar
My car idles fine with A/C on but if I go to start in 1st gear the car will NOT ACCELERATE at all even if it is floored and acts like it is going to stall until I turn off the A/C. Once it gets above about 2k rpm it is fine... Weird. I only use the A/C on the freeway now It only acts like this when it is hot out.... how convenient...
Dustin
kcjohnnyboy
Dec 23, 2005 09:36 PM
gsr2000
Aug 7, 2005 09:45 PM
Linger
Jun 13, 2003 08:30 PM
kuelerz
Sep 23, 2002 12:16 PM
Dorikamu
May 3, 2002 11:26 AM
