compression fitting at boost gauge
Old Sep 6, 2001 | 11:02 AM
schwett's Avatar
New User
Default compression fitting at boost gauge
hey guys
do these 1/8" compression fittings (accepts a small stiff nylon tube, you put a little brass sleeve over it and screw together) require teflon tape to make an airtight seal? i think i'm hearing a slight pssshhhhh noise from my boost gauge! the pressures seem right though, so it must be very slow if it's there at all. i don't really see where the tape should go besides on the threads - does the little ball make a tight seal with the hollow nut just from tightening it?
Old Sep 6, 2001 | 11:22 AM
boomslang's Avatar
Default Re: compression fitting at boost gauge (schwett)
You don't want to put any teflon tape on compression fittings.
But since it is leaking...JB Weld the sumbitch.
Old Sep 6, 2001 | 06:55 PM
DirtyLude's Avatar
Default Re: compression fitting at boost gauge (Inlinefour)
Those nylon tubes always seem to crack. It took me a while to narrow down my vacuum leak to that damn boost gauge.
Old Sep 6, 2001 | 08:31 PM
redline's Avatar
Default Re: compression fitting at boost gauge (DirtyLude)
That is the best reason to buy a good greddy, apexi etc... gauge and not deal with the crappy lines in the first place!!
turbo gsr2000
Aug 4, 2009 11:02 AM
roni_xxp
Engine Management and Tuning
Mar 26, 2009 09:37 AM
ImPuLsIvE
Sep 17, 2007 09:53 AM
falcongsr
Jul 3, 2001 03:14 PM
