What should i watch out for when using ZEX???
Old 09-05-2001, 07:39 AM
New User
soler's Avatar
Default What should i watch out for when using ZEX???
i have a pretty stock engine just intake and exhaust
what do i have to watch out for???
any suggestions
how many times before my engine blows???
Old 09-05-2001, 09:09 AM
redline's Avatar
Default Re: What should i watch out for when using ZEX??? (soler)
Just retard your timing and upgrade your fuel pump and you should be fine. Do not hit the NOS every stop light and things will go better!
There is no set limit till your engine blows! it all depands on tuning and use! Use your head and the engine should last a long time!
Old 09-05-2001, 09:25 AM
TypeC's Avatar
you don't need to retard timing or get injectors with the 55 shot. It comes with a chart. at 65 shot retard 2 deg, 75 shot retard 4 and get a fuel pump. I just played it safe and stuck with the 55 shot. HTH, -C
Old 09-05-2001, 10:33 AM
New User
mercury's Avatar
Default Re: What should i watch out for when using ZEX??? (TypeC)
More questions:
Is it okay to leave the bottle open all the time? I assume there's a valve near the bottle.
How exactly does the purple box work? Does it trick the fuel pressure regulator into raising the fuel rail pressure?
If you hit the rev limiter, the ECU will cut fuel, right? Won't this cause an extreme lean condition and detonate the engine?
nitroaccord105
07-18-2007 12:32 PM
msbhvn_DC2
02-16-2006 12:41 PM
YourHondaSucks
02-08-2004 03:30 AM
willyboyK20
03-19-2003 05:20 AM
xxplosif1
04-21-2002 07:06 AM
Quick Reply: What should i watch out for when using ZEX???
