Overcoming VTEC on a turbo
Old Sep 6, 2001 | 11:41 PM
Kamin's Avatar
Default Overcoming VTEC on a turbo
Ok, ive heard several stories on how when vtec kicks with a turbo kit it sputters or somthing, i think this is called cam float, when it switches from lo to high lobe cams. why does this happen and is there anyway to overcome this without playing with the valve timings? thanks! i like this board BTW im glad i found it
Old Sep 7, 2001 | 12:03 AM
D-SPEED's Avatar
Default Re: Overcoming VTEC on a turbo (KAMiN)
ive never heard of anything like this, and ive never seen a dyno chart reflect such a thing. not sure though...
Old Sep 7, 2001 | 12:37 AM
dustin's Avatar
There is no such problem so you can stop worrying
Dustin
Old Sep 7, 2001 | 12:48 AM
Kamin's Avatar
Default Re: Overcoming VTEC on a turbo (dustin)
wow
cause i know people that this has happened to. its probably injector related lol. THANKS
now i feel like an *** tho
Old Sep 7, 2001 | 04:59 AM
bQQsted hybrid's Avatar
Actually that problem does happen (it happened to me) but it is mainy fuel related, and can be fixed with minimal tuning.
Old Sep 7, 2001 | 05:02 AM
b18bturbo's Avatar
Default Re: Overcoming VTEC on a turbo (bQQsted hybrid)
actually you willalways see a slight dip when vtec kicks in then as soon as cam changed to high it will kick back. Even on the race car. it drops like 5hp and then jumps 60hp when it kicks back.
Old Sep 7, 2001 | 06:45 AM
VTC_CiViC's Avatar
Default Re: Overcoming VTEC on a turbo (b18bturbo)
I've heard of VTEC slightly "hurting" boost some when the big cam kicks in thanks do the jump in overlap (bleeding a little boost) and it seems on my Civic I have a similar situation (at about 5700rpm boost will drop .5 psi), but as far as sputtering or inhibiting the car, never heard.
Old Sep 7, 2001 | 11:02 AM
integRated109's Avatar
i drop about 12 hp right at switchover, but it only lasts about 300 rpm. hopefully VAFC and cam gear tuning will fix it.
Old Sep 7, 2001 | 11:10 AM
Kamin's Avatar
Default Re: Overcoming VTEC on a turbo (integRated109)
SEE i knew i wasnt crazy, good to know its a minimal problem and it is fuel related, probably just bigger injectors and a fuel rail will help it right?
thanks guys
Old Sep 7, 2001 | 11:39 AM
VTC_CiViC's Avatar
Actually, proper fuel managment and cam tuning will help quell the problem, thing that sucks for me is, I've got a SOHC, so I can't really "tune" down the overlap like DOHC guys can. The fuel dip though I can manage when I get my V-AFC.
xSOHC
May 24, 2012 06:49 AM
Andrea_Aunie
May 27, 2002 12:39 PM
Andrea_Aunie
May 26, 2002 08:17 PM
SpeedMonkeyRacing
Jan 17, 2002 10:56 PM
