310s?!!
Old Aug 29, 2001 | 05:29 PM
revhrdls's Avatar
Default 310s?!!
What's the most boost 310s can handle without running lean? with the aid of an inline, stock ecu rev hard II ls engine
Old Aug 29, 2001 | 06:00 PM
Jared's Avatar
Default Re: 310s?!! (revhrdls)
depends on unlimited factors
-turbo size
-engine size
-fuel pressure
-how quickly boost builds
-ECM program
-fuel pump
-cam timing
there's really no way to approximate exactly, but I would guess 8psi
Old Aug 29, 2001 | 06:49 PM
Mikex25's Avatar
New User
Default Re: 310s?!! (Jared)
many people have done 10 psi on the B18B(LS engine) All you need to do is 310 injectors get a 8:1 FMU disk and some sort of fuel control device like a V-afc.
Old Aug 29, 2001 | 08:35 PM
redline's Avatar
Default Re: 310s?!! (Mikex25)
I did 10psi with 310s and everthing was a OK on stock GSR engine
Old Aug 29, 2001 | 08:53 PM
Mikex25's Avatar
New User
Default Re: 310s?!! (redline)
Redline did you have engine management, a lot of people told me I can't do 10 psi on my GSR
Old Aug 30, 2001 | 12:11 AM
Crxlsturbo's Avatar
yes the stock LS engine can handle up to 15psi with 310 injectors. But the motor will not last that long. Stock LS injectors can boost up to 10psi with race gas. But with 310 injectors you can safely run 12psi on race gas. The reason why the V-Tec motors can't boost that high is because of the higher compression. Hence that is why the LS motor loves boost. Hope this helps.
Marc
Old Aug 30, 2001 | 12:25 AM
redline's Avatar
Default Re: 310s?!! (Crxlsturbo)
I have 310cc injectors, 8:1 vortech, MSD 6BTM, J&S knocksensor, walbro 255l/h HO pump. I have run 10psi on 92 octane with the BTM on and 10psi no BTM with VP103. and the car runs safely rich!!!
k
Old Aug 30, 2001 | 01:27 AM
Mikex25's Avatar
New User
How come you have the MSD 6TM and the J&S knock sensor don't they both do basically the same thing?
Old Aug 30, 2001 | 09:15 AM
redline's Avatar
Nope not even close! The BTM retards timing based on psi of boost and the old school J&S that i have only retards timing when it sees knock!!
k
jamesfawcett
Apr 13, 2010 01:33 AM
95dc2teg
Jul 16, 2006 12:58 PM
dc9turbo
Sep 20, 2005 07:33 PM
B18-T
Aug 3, 2002 10:21 AM
Chip398193
Nov 19, 2001 10:55 AM
