hack questions
Old Sep 15, 2003 | 08:46 AM
machine4321's Avatar
Default hack questions
ok i searched for a little over an hour and i found lots of problems and solutions ....
but what i couldnt find is the reason for runnign the hack and how to run the hack ie,how to wire it up ...i need to know the whole deal on them ....
i have a vafc will it work
thanks
Old Sep 15, 2003 | 09:49 AM
R6Elmo's Avatar
Default Re: hack questions (machine4321)
You searched for an hour and couldn't find a reason why to run the afc? Some people run it b/c they can't afford a hondata, or they dont' want to run the FMU Many reasons why people run it. I like it b/c of the on the fly tuneablity.
How to wire? go to http://www.apexi-usa.com and click documents. You'll find some instructions there on how to wire in the afc. Pretty easy...30 min tops.
Old Sep 15, 2003 | 10:00 PM
well i was in the middle of reading the 5 page topic on it and it seemed every one already knew about and i couldnt figure it out ...
but i have the vafc wired already so step one is done ...wasnt sure if internally it had to be changed......it being called a hack and all i figured it was more complex then i though
Old Sep 15, 2003 | 10:07 PM
NuclearB18B's Avatar
Default Re: (machine4321)
http://www.thedropshop.tv/vafc.htm
hope this helps
Old Sep 16, 2003 | 06:07 AM
oh yes thank you .....thank you
Old Sep 16, 2003 | 06:43 AM
VTC_CiViC's Avatar
3-steps to it:
1- Wire the AFC
2- Install the injectors
3- Set the AFC trim appropriate to the injectors used
project civic
Mar 31, 2005 06:39 PM
Inducted
Jan 11, 2004 07:57 PM
redlinex
Sep 19, 2003 06:09 PM
Big Josh
Feb 15, 2003 04:18 PM
dp
Oct 20, 2002 11:48 AM
