Peak & Hold or saturated
Old Sep 16, 2003 | 08:07 AM
VanHonda's Avatar
Default Peak & Hold or saturated
I have a 2000 Si on the AFC Hack with the DSM 450's. If I were to get new RC injectors, should I get RC peak & hold or re-wire and get the RC saturated injectors. If I get peak & hold what size should I get?
Thanks,
Craig
Old Sep 16, 2003 | 08:10 AM
T3T495GSR's Avatar
Default Re: Peak & Hold or saturated (VanHonda)
get 440cc saturated injectors, its a direct fit
Old Sep 16, 2003 | 08:19 AM
drvfast's Avatar
go with the saturated injectors
Old Sep 16, 2003 | 08:47 AM
Nextelbuddy's Avatar
Default Re: Peak & Hold or saturated (drvfast)
actually i would get the peak and hold. why you ask. well you just said that you alreayd have the dsm injectors in your civic. well that would imply that you are running a resistor box as well. if you get the rc injector in saturated versions then that means you are going to have to take out the resistor box and rewire your injector wires again. now if you meant to say that you have a 99 civic and 99 dsm injectors laying arond that havent been installed yet then yes go ahead and get the saturated injectors then
sevenj
May 21, 2008 04:50 PM
ironiceghatch
Feb 11, 2008 01:26 PM
Schister66
Apr 26, 2006 08:36 AM
boost_is_best
Feb 28, 2006 03:45 PM
