Are you guys running -10 or -6 Feed lines now? Im tryin to decide
I know aloota people have been running the -6 feed and returns...But lately ive seen a few people saying run -10feed and -6 return. Whats yalls opinions on this?
Im gonna be running 9:1, hi boost with AEM, T3/T3 for now, bigger later
Re: Are you guys running -10 or -6 Feed lines now? Im tryin to decide (SIReg9)
run a -10 or even -6 AN feed to your turbo and watch it explode in a great ball of oil Run a -3 for the feed, and -10 for the return.
Re: Are you guys running -10 or -6 Feed lines now? Im tryin to decide (boostaholic)
Sorry i was specific...i was talkin about Stainless lines for my fuel system
Im shootin at 425+, if i upgrade the turbo... 500+
I just dont wanna have to go back and upgrade later, im gonna prepare to upgrade, becuase im gonna do it eventualy.
Im pretty much just tryin to figure out wich external regulator to buy, either the -10 or -6
-6 should be good to what power you want to make..but so will the stock fuel lines...i believe the stock is already pretty close to the size of a -6 so if you just removed some of the restrictions in it like banjo fittings with an fittings you should be fine..
if you really want to upgrade ide go with -8..that will be plenty big for your setup and lines and fittings will be cheaper then -10
Re: Are you guys running -10 or -6 Feed lines now? Im tryin to decide (gritsak)
The only FPR's ive seen have -10 and -6 inlets, So can i get the one with -10 inlets and run -8 lines?
My friend said he's running -8 on his Hatch
just run a -8 feed and a -6 return and run the regulator off the return...but they should make the right size fitting for the FPR in a -8 though
Im gonna go to aeromotives site and see how many FPR's they list and get the part # i guess
-8AN feed is plenty big for 500whp. The aeromotive fpr comes in -10 and -6 inlets. Just get an adapter, -8 to -10, for the fpr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic »</TD></TR><TR><TD CLASS="quote">-8AN feed is plenty big for 500whp. The aeromotive fpr comes in -10 and -6 inlets. Just get an adapter, -8 to -10, for the fpr. </TD></TR></TABLE>
Thats the answer i was lookin for...-10 FPR it is
Re: Are you guys running -10 or -6 Feed lines now? Im tryin to decide (rOby)
T3/T4 .60 trim with .63AR
Ive been told by a few tuners i could get that much outa the motor with AEM EMS and 25+PSI
I am a bad person
I run a -10 to the pump, -8 to rail and -6 return. that setup seems to be what most people run i think.
Re: Are you guys running -10 or -6 Feed lines now? Im tryin to decide (MotorMatrix.com)
MotorMatrix... You wouldnt have that oh so complicated list of Part #'s would you I have a list of what conectors i need, its just im uncertain on how many feet of each size tubing i need
stock lines are good for 550-600 to the wheels for sure. i would go to -8 for like 550-650 and -10 for 650 plus. seriously under 525, stock lines are fine.
Re: Are you guys running -10 or -6 Feed lines now? Im tryin to decide (jinxproof99)
"seriously under 525, stock lines are fine." I had no fuel pressure drop until over 580whp with stock lines and 255hp pump. If you are going to upgrade run -10 feed.
