When to stop boosting .....
Old Sep 14, 2003 | 07:19 PM
b20turboic's Avatar
Default When to stop boosting .....
I have a bone stock JDM 96 B20B 8.8 ratio... with dsm 450's and a zdyne gold computer with a 255 hp fuel pump and base fp is set at 60... right now im hitting from about 10.8-11.5 psi and not a sign of weakness in the tune yet.... just raced a fast talon today and did a 5th gear pull till 6800-6900 at 11.5 psi and it didnt break or anything. Should i stop here or try to pull a little more out of the car this year ... ( I run min. of 94 octane usually 104-108 ) Just need some info from people who have a great running tune and havent messed stuff up how far should i push it because people seem to push upwards of 20 psi on stock blocks thanks alot guys
o yeah ran 13.2 at 110 mph on shitty 14 inch tires ....
Modified by b20turboic at 1:54 PM 9/15/2003
Old Sep 15, 2003 | 04:54 AM
b20turboic's Avatar
Default Re: When to stop boosting ..... (b20turboic)
ttt
Old Sep 15, 2003 | 06:25 AM
VTC_CiViC's Avatar
5th gear boosting thru the redline eh? You're pretty brave man!! The EGT's skyrocket boosting that high a gear for so long, a pretty good invitation for detonation without a precise tune, but hey if it's working for you..
Old Sep 15, 2003 | 07:01 AM
b20turboic's Avatar
Default Re: When to stop boosting ..... (VTC_CiViC)
thats what i mean i did the most stressfull thing to it and it still took it like a biznatch i just see people on here running 1 bar and stuff on stock motors and wanted to see peoples stories pro/con and such thanks for the input though
Old Sep 15, 2003 | 07:16 AM
Foozball26's Avatar
I've been to about 7k rpm in 5th on my LS tranny...162 mph woot
but my friend chickened out and said stop...I still had 700 rpm to go.
still running well
edit: my block is built btw forgot to mention that.
Modified by Foozball26 at 10:31 AM 9/15/2003
Old Sep 15, 2003 | 07:21 AM
VTC_CiViC's Avatar
Yea, I ran alot of boost on a stock single cam too.. but I didn't push it through 5th!!
Think about the pressure/heat in those cylinders, and think of the time spent accelerating through 5th. Think now how immensely hot the surface edges of the pistons, the valves, and spark plug must have been when you wound out 5th with 11 or 12psi. Not to mention the common thought is tha B20 sleeves are a little shady to begin with.. I mean like I said, if it worked for you then But me personally, I think I'd rather have a sleeved block and forged slugs in there for boosting that much, but that's just me
Old Sep 15, 2003 | 07:30 AM
highmilehatch's Avatar
Don't you guys think that boosting in fifth would depend on how the engine is tuned? I mean, an engine boosting in fifth with an aggresive timing and fuel curve would certainly cause more thermal stress than an engine tuned with a very rich and conservative timing curve correct? As long as the egts stay within a constant safe zone during that time, do you think it would still be a bad idea?
Old Sep 15, 2003 | 07:34 AM
Foozball26's Avatar
Default Re: When to stop boosting ..... (highmilehatch)
It's safe as long as its properly tuned for that activity and the engine characteristics are within acceptable limits
Old Sep 15, 2003 | 07:42 AM
Hoosier Daddy's Avatar
Default Re: When to stop boosting ..... (Foozball26)
I don't know about you guys, but I'm boosting only 6psi on my B20 and 5th gear certainly isn't a long one...
Old Sep 15, 2003 | 07:43 AM
b20turboic's Avatar
for Foozball26 and Highmilehatch for understanding the tuned part.. im tuned at 11.0-11.5 ratio with about 4.5-5 degree timing retard at full boost so its not that aggressive. Keep the info coming guys also have full OBD0 datalogging
Old Sep 15, 2003 | 09:08 AM
R6Elmo's Avatar
11.0-11.5 a/f is pretty rich. I'd say that's on the conservitive/safe side which is good for a stock block.
Old Sep 15, 2003 | 09:21 AM
b20turboic's Avatar
Default Re: When to stop boosting ..... (R6Elmo)
yeah boost creep at 11 its reall really short haha
Dark_Teg
Oct 5, 2013 08:43 PM
blackeg
Aug 9, 2010 04:31 PM
pissedoffsol
May 31, 2004 06:41 PM
Sinner
Sep 22, 2003 10:57 PM
ElectronVTEC
Feb 3, 2002 09:25 PM
