Custom fuel line. What size banjo???
Old 09-16-2003, 02:07 PM
Lyrikz's Avatar
Default Custom fuel line. What size banjo???
Im making a custom fuel line from the fuel filter to the fuel rail. What size banjo do i need?? Its for a 1992 civic fuel filter..
Also, any recommendations on where to purchase the banjo???
Here is what im looking for
The fuel line will be -4an but what size should the banjo opening be to fit stock?? Thanks.
Old 09-16-2003, 02:12 PM
R6Elmo's Avatar
Default Re: Custom fuel line. What size banjo??? (Lyrikz)
try to see if summitracing or anplumbing has them.
Why not just run a universal fuel filter with an fittings? Those are cleanable, and don't cost too much. Just another option for you to consider. I actually have a -6an earls filter here if you want hehe.
Old 09-16-2003, 04:15 PM
gritsak's Avatar
Default Re: Custom fuel line. What size banjo??? (R6Elmo)
screw the banjo crap all together...just order a 12x1.25 to -6 (if you want to run -6 that is)
PM flamincoT (sp?) he can get it for you
Old 09-17-2003, 07:04 AM
Lyrikz's Avatar
Default Re: Custom fuel line. What size banjo??? (gritsak)
uh, i still need the banjo end for the fuel rail side of the hose right??? What can i use for that??? Or should i just pull that out???
Let me know.
Old 09-17-2003, 07:06 AM
redlinegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">screw the banjo crap all together...just order a 12x1.25 to -6 (if you want to run -6 that is)
PM flamincoT (sp?) he can get it for you</TD></TR></TABLE>
Its Flamenco-t. His name is Stan and he is known as the "fitting" man.
Old 09-17-2003, 07:27 AM
Lyrikz's Avatar
Default Re: Custom fuel line. What size banjo??? (redlinegsr)
Well, i want to make it myself. I know stan, he is the man with that stuff. I just want it all done by my onezees.
eg:R
03-05-2010 05:00 PM
h22sedan
11-08-2006 06:02 PM
senpai
07-20-2003 09:40 AM
D0HC
12-19-2002 01:23 PM
Arturbo
02-05-2002 04:05 PM
Quick Reply: Custom fuel line. What size banjo???
