what are the clearance specs for rod bearings and main bearings(b16a1)
i'm replacing the mains/rod bearings in my motor. what are the clearance specs for the mains and rods i need to be within when i plastigauge them?
Re: what are the clearance specs for rod bearings and main bearings(b16a1) (crx1856)
if you're trying to put a motor together without a manual (torque and measurement specs)in fron tof you, I'd highly reccomend against it. I have teh specs for the b18c1 and b18b/a, I could tell you but I'm not sure if the b16 is teh same
Re: what are the clearance specs for rod bearings and main bearings(b16a1) (Paul_Vang)
b18c1
main:#1,2,4,5 .024mm-.042mm(.0009-.0017in) limit:.050mm(.0002in)
#3 .030mm-.048mm(.0012in-.0019in) limit:.060mm(.0024in
rod:.032-.050mm(.0013-.0020in) limit: .060mm(.0024in)
b18b/a1
main: same as above
rod: .020-.038mm(.0008-.0013in) limit: .050mm(.0020in)
b18b/a1
main: same as above
Ryler808
06-13-2012 08:10 AM
Civic483973
07-10-2010 08:39 PM
