built turbo motor question
Old Sep 14, 2003 | 07:29 PM
B18B1DOHC's Avatar
Default built turbo motor question
what else can i do to my LS motor to make it better for turbo? i already have pistons, rods, metal heas gasket, valve springs.
Old Sep 14, 2003 | 07:38 PM
Jared's Avatar
Default Re: built turbo motor question (B18B1DOHC)
Get a bigger set of cams and have the block sleeved.
Old Sep 14, 2003 | 07:56 PM
gritsak's Avatar
Default Re: built turbo motor question (Jared)
all arp hardware is always good insurance
Old Sep 14, 2003 | 08:11 PM
B18B1DOHC's Avatar
Default Re: built turbo motor question (gritsak)
wuts arp hardware
Old Sep 14, 2003 | 08:16 PM
turbolsintegra26's Avatar
I just cracked a sleeve yesterday on my B18B. I have rods, pistons, arp, block guard, and cracked my fourth sleeve @ 20 psi. oops. have s-afc hack W/ 450 cc injectors. ran 13.98 @ 108 at 14 psi on 17in wheels. So my point is get your block sleeved.
Old Sep 14, 2003 | 09:14 PM
civicsitek GanGsTa's Avatar
Default Re: built turbo motor question (Turbointegra22)
arp makes head studs and other bolts and studs. How far do you wanna take the build up?
Old Sep 14, 2003 | 09:29 PM
B18B1DOHC's Avatar
Default Re: built turbo motor question (civicsitek)
i want to at least run high 12's or low 13's...what do you guys suggest?
Old Sep 14, 2003 | 10:10 PM
B18B1DOHC's Avatar
help
Old Sep 14, 2003 | 10:15 PM
igotyofire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbointegra22 &raquo;</TD></TR><TR><TD CLASS="quote">I just cracked a sleeve yesterday on my B18B. I have rods, pistons, arp, block guard, and cracked my fourth sleeve @ 20 psi. oops. have s-afc hack W/ 450 cc injectors. ran 13.98 @ 108 at 14 psi on 17in wheels. So my point is get your block sleeved. </TD></TR></TABLE>
your point doesn't prove anything, im sure most people here know not to run 20psi on stock sleeves. not to mention at 14psi and only running a 13.98, either u cant drive or somthing with your setup is wrong? what is your turbo setup and specs. but your right sleeving is a good thing
Old Sep 14, 2003 | 11:21 PM
nevin's Avatar
or maybe it was the 20 psi on 450s and afc haha
Old Sep 14, 2003 | 11:24 PM
B18B1DOHC's Avatar
but i was told that i dont need sleeves becaust i am not running high horsepower...only 10 psi
Old Sep 14, 2003 | 11:39 PM
reaction360's Avatar
how's he running that much boost 14-20 on an afc hack? 3 bar map sensor? actualy, y am i askin, he blew it.
Old Sep 14, 2003 | 11:46 PM
B18B1DOHC's Avatar
Default Re: built turbo motor question (reaction360)
hey guys..this is my forum..stop talkin about something else..haha jk
Old Sep 15, 2003 | 06:33 PM
If you are only gonna run 10 psi you (should) be ok with stock sleeves. If you have to go faster in the future, and I can promise that you will, you might want to think about sleeving. IF you think you will be happy with 10 psi, Id just get the arp hardware and balance the bottom end and call it good. Maybe thermal coat your exhaust valves and combustion chamber.
Old Sep 15, 2003 | 07:43 PM
AlLMoToRvOtEr's Avatar
You could get rid of the LS head period and get a Vtec head and you would see huge gains with VTEC.....................
Old Sep 15, 2003 | 09:35 PM
T4eg's Avatar
get it sleeved and turn the boost up
Old Sep 16, 2003 | 09:53 PM
B18B1DOHC's Avatar
bump
Old Sep 16, 2003 | 10:12 PM
Ri5e's Avatar
You don't really need to sleeve it, it's been proved that the stock sleeves are quite strong. It's all about fuel/timing management and tuning. I mean, you have a super sleeved block, but it isn't gonna withstand detonation if its unproperly tuned. So get Hondata, EMS, etc...
Old Sep 17, 2003 | 08:13 AM
ScandalousCivic's Avatar
Default Re: built turbo motor question (abiliTy)
Sleeve that block if you want it to last forever. Putting a bigger set of cams in the head, would kind of be like having vtec all the time, but it's probably cheaper to find a used b16/b18c head.
arp headstuds =
japspecnegro
Feb 25, 2005 07:35 AM
Teglove2
Jan 28, 2004 03:59 PM
DOHCarp
Dec 27, 2003 02:28 PM
turbolsintegra26
Sep 15, 2003 06:52 PM
