Turbo Problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 15, 2003 | 04:53 PM
ATS*Mark's Avatar
OG triple OG
Default Turbo Problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i need help bad i dont know what to do....
i got a greddy tdo4h kit on my 99 ex . we installed the turbo , and it was smoking bad!!!!!! oil iwas getting into the charge pipes via the turbo somehow..... the shop sent the turbo in to get warrentied out . they said they found "nothing" wrong but rebuilt it anyway.....ok so i get it back , and it does the same ******* thing!!!!!!!!!!!!!!!!!!!!! i dont get it . any help please what should i do ?????????? am i missing somthing or what!!!!!!!!!!! its driving me nuts
Old Sep 15, 2003 | 04:58 PM
psileepR's Avatar
New User
Default Re: Turbo Problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (TURSpoonEK)
what does your oil return look like? any kinks? is it a straight down drop to your oil pan or does is curve back up?
Old Sep 15, 2003 | 05:04 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Turbo Problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (psileepR)
it like bends down a little bit then goes flat
but even so it shouldnt be leaking through the compressor right....
Old Sep 15, 2003 | 05:10 PM
AlphaKennyWun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK &raquo;</TD></TR><TR><TD CLASS="quote">it like bends down a little bit then goes flat
but even so it shouldnt be leaking through the compressor right....</TD></TR></TABLE>
it might. the return line works on gravity so if the oil is not flowing out of the turbo fast enough then it backs up and you would have a problem
it really should be at a pretty big slope downward and no less than a -10 line. Also should be up high on oilpan
Old Sep 15, 2003 | 05:17 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Turbo Problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (S03Burner)
it is high on the pan , there isnt much of a slope in the line , its a big line too....
Old Sep 15, 2003 | 05:18 PM
ATS*Mark's Avatar
OG triple OG
its the line that came in the greddy kit...
Old Sep 15, 2003 | 05:36 PM
Blown90hatcH's Avatar
Snap some pics man so we can see.
Old Sep 15, 2003 | 05:55 PM
Default Re: Turbo Problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Snap some pics man so we can see. </TD></TR></TABLE>
what he said
Old Sep 15, 2003 | 06:51 PM
ATS*Mark's Avatar
OG triple OG
im uploadin pics right now , i tried to snap angles of the return line......i think thats where the problem lies... i just dont get it....
Old Sep 15, 2003 | 07:23 PM
ATS*Mark's Avatar
OG triple OG
add .orig.jpg to see the large version.....
Old Sep 15, 2003 | 07:31 PM
Quad-Damag's Avatar
U might be missing the gasket that goes right there
Old Sep 15, 2003 | 09:34 PM
Adub33's Avatar
Default Re: (Quad-Damge)
I am having the same problem. I would like to know what is happening as well.
Old Sep 15, 2003 | 09:35 PM
rjardy's Avatar
Whats with all the oil on the manifold? Looks like you have a leak somewhere.\
Rob
Old Sep 15, 2003 | 09:36 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (rjardy)
ya i know i have a leak
Old Sep 15, 2003 | 10:29 PM
Quad-Damag's Avatar
Default Re: (TURSpoonEK)
NO METEL Gasket, Look at this pic, it has one here
Old Sep 16, 2003 | 03:55 AM
ATS*Mark's Avatar
OG triple OG
I still dont see how that would cause oil to inter the charge pipes
Old Sep 16, 2003 | 04:27 AM
djmatix's Avatar
is your valve cover breather port hooked up to your charge pipe? some kid brought his turbo ex up to the shop and he had that hooked up there. his blow off valve was spraying oil everytime he blew off. you dont want that hooked up to a compressed pipe, the intake pipe if any, and i'd not reccomend that either. put a breather filter on it. i've had that turbo setup myself and didnt have that problem.
Old Sep 16, 2003 | 04:43 AM
boonacka's Avatar
sorry this is off topic, but what size is the greddy turbo and how does it compare to the garrett t25?
i figure the only way oil is getting into the intake or into the compressors is because of a bad seal at the center section (bearings) of the turbo. theres no other way for the oil to get there. faulty turbo?
Old Sep 16, 2003 | 05:30 AM
Default Re: (boonacka)
After seeing pics i dont think the return line looks too bad. Is oil only getting into the exhaust side of turbo or the charge side too?
Old Sep 16, 2003 | 06:40 AM
DaveF's Avatar
Default Re: (S03Burner)
in the pic you can clearly see that the valve cover breather tube is connected to the intake pipe(going into the compressor housing) that would cause oil to be sucked into the compressor housing and pushing it through the charge pipes.
put a breather filter on the valve cover.
Old Sep 16, 2003 | 06:49 AM
VTC_CiViC's Avatar
Default Re: (2.2Lcivic)
Actually, all I see is the hose comming off the valve cover and bending down, can't see where it goes but I'll assume it does connect to the charge pipe which is why you're sucking oil out of the head and into the charge piping.
Attatch that line to the intake pipe just behind the filter, there should be a nipple just for that on there.
Old Sep 16, 2003 | 07:18 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (VTC_CiViC)
im not sure if oil is getting on the intake and exhaust side , because oil is getting through the hole motor via the charge pipes . the valve cover vent is hooked up to the pcv(i think) then from the pcv to the charge pipe......
Old Sep 16, 2003 | 07:29 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK &raquo;</TD></TR><TR><TD CLASS="quote">im not sure if oil is getting on the intake and exhaust side , because oil is getting through the hole motor via the charge pipes . the valve cover vent is hooked up to the pcv(i think) then from the pcv to the charge pipe......</TD></TR></TABLE>
Wha!? Return the PCV back to the stock setup and run the valve cover breather. Clean your intake piping and put it all back on.. should be A-ok
Old Sep 16, 2003 | 09:27 AM
Quad-Damag's Avatar
^^ I told him that online
The hole on your Greddy Filter, Make that Connect to your TPS Sensor, just stick it at the end of the filter and the hoes to the filter, and run a oil breather on your engine, DONE and DONE, and get that gasket for your downpipe
Old Sep 16, 2003 | 12:55 PM
ATS*Mark's Avatar
OG triple OG
i know its not those lines theres no oil in them!!
