How many turbo people run 10+ psi on stock internals?
I recently found out that my boost guage wasnt reading right. Or maybe it was, but here is the situation. I bought a tial wastegate off of a friend. I thought it was a 35mm because I had no previous expierience with external gates coming from a sohc greddy turbo on my b-series. Turns out, the wastegate is a 35/40 hybrid and it had a BIG red spring in it. My friends and I up at the shop almost **** when we found out that i wasnt really boosting 8psi but 11 or more instead. So my car was a demon at a supposed "8" psi, or .56-.58 bar, which the AFC and the boost guage was reading. Well, the car is fine, nothing wrong with it, no oil burning nothing, but I was wondering if anyone else boosts more than 10psi on stock internals.
i've got ARP head studs and a CHM performance block guard and thats it for internals. Stock compression with the stock head gasket.
thanks!
thanks!
Re: How many turbo people run 10+ psi on stock internals? (boostsohfast)
i run 1 bar daily on a BONE stock LS, never even takin the head off before. i ran it so long that i had a built motor sitting on the floor WAITING to be installed. IT wouldnt go, so i just put my new one in. Now my built motor is giving me trouble
Honda builds 'em best
Re: How many turbo people run 10+ psi on stock internals? (djmatix)
I think just as important as how much boost you're running is what you're using for engine mangement. That said, what are you all using?
Re: How many turbo people run 10+ psi on stock internals? (johnisenglish)
Bone stock D16Z I am boosting 11 psi. I would go higher but I am at the map sensor limit. It runs perfect. This is on a tuned hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnisenglish »</TD></TR><TR><TD CLASS="quote">I think just as important as how much boost you're running is what you're using for engine mangement. That said, what are you all using?</TD></TR></TABLE>
Electromotive TEC2
Electromotive TEC2
Re: How many turbo people run 10+ psi on stock internals? (LSiTurbo)
well since on the suject 10psi daily. How safe is it really, I'm planning turbo but didn't know what would be a safe setting. Also i'd only pull it hard on occasion so not everyday of every minute. Thanks.
Re: How many turbo people run 10+ psi on stock internals? (silvrintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvrintegra »</TD></TR><TR><TD CLASS="quote">
well since on the suject 10psi daily. How safe is it really, I'm planning turbo but didn't know what would be a safe setting. Also i'd only pull it hard on occasion so not everyday of every minute. Thanks.</TD></TR></TABLE>
It is safe if it is tuned right. I run mine to 7700 rpm all the time without a problem. This is on a big .63 ar turbo.
Re: How many turbo people run 10+ psi on stock internals? (b20turboic)
The 35/40 hybrid is tial's 38mm offering.
I don't understand how your gauges were reading lower than what you were really boosting??
-PHiZ
-PHiZ
I will be running 10psi, on stock b16, w/ proper fuel management....Tuning is the key.
Re: How many turbo people run 10+ psi on stock internals? (COOKIEPUSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by COOKIEPUSS »</TD></TR><TR><TD CLASS="quote">
I will be running 10psi, on stock b16, w/ proper fuel management....Tuning is the key.</TD></TR></TABLE>
Did you reduce the compression at all??
-PHiZ
-PHiZ
Re: How many turbo people run 10+ psi on stock internals? (PHiZ)
Ok im sure u guys have seen the Rev Hard stage 2 kit right? Im running stock internals think if i just smacked the kit on there ill be alright for a little while ? till Injectors, Je pistons, rods etc etc come??? The kit comes with just about everything..I was just going to get block guard installed with kit...This sound ok to u guys? sound safe?
HELLO,GOOD MORNIN'
Re: How many turbo people run 10+ psi on stock internals? (Acronym)
me..........11psi.........hondata............it all depends on your tuner. I have Tony! jotech
I have successively ran 22lbs, stock internals, stock sleeves two years ago on race gas. I ran 1.1bar daily on pump gas I was using a .076" thicker headgasket and arp head studs. I was making 420whp at 21~22psi, the engine lasted for the entire time I used it (2-3 months). I had issues with my sleeved block, I ended up putting the same stock block back in again making 350whp on pump gas @11psi now.
Re: How many turbo people run 10+ psi on stock internals? (C R X)
An aftermarket sleeve companies sleeves did not seal properly when installed. The coolant seeped into the oil pan.
Re: How many turbo people run 10+ psi on stock internals? (94goldjungsr)
1.0 bar....inlne pro 2mm hg, arp head studs, stock internal b16, and hondata.
was running a half bar....got boreing, then .7 bar.....still not enough....at 1.0 bar...im satisfied for now.
Re: How many turbo people run 10+ psi on stock internals? (boosted hybrid)
what motor you have boosted hybrid ... im thinking about 1 bar on my b20 if you want aim me b20turboic i wanna see if its possible for this weeks race thanks man
