hot start problem?
Old Sep 16, 2003 | 08:08 PM
SiRkid's Avatar
Default hot start problem?
My car has DSM 450 injectors.
If its cold. I starts fine. If its warm/hot it generally starts fine BUT everytime I come to my car after school it will start but be COMPLETELY not firing on one ccylinder.
I drive to school(its fine) then park it and it sits for like 5 hours or so(in the sun) and thats when I get this problem.
Now, i know its the injector because I was having a misfire problem before and it was due to my injecor plug being half off
this happend after my dumb misshift (the motor is fine though)
So im getting the same symptoms as when I had the misfire before except it ONLY happens when I get in it at school(After its been sitting)
After about 2 mins when it warms up a bit,
the car is NORMAL..and it wont misfire again at all.
WTF???
im starting to think I couldve fugged an injector on my misshift or something.
Its totally wierd.
At least its consistant though. I usually know when it will happen(after class when its been sitting for a while in the sun)
Any idea what could be causing it?
Old Sep 16, 2003 | 08:14 PM
greekspeed's Avatar
Default Re: hot start problem? (SiRkid)
maybe check ur resistors or resistor box for ur injectors to make sure all the resistors are fine... maybe they arent working like they are suppose to due to resistor overheating? or maybe the connection is bad.
only advice i can think to give.
Old Sep 17, 2003 | 05:11 PM
SiRkid's Avatar
Default Re: hot start problem? (greekspeed)
thanks for the reply.
I like how no one replies to my somewhat tech threads unless I complain about it.
maybe if I asked which turbo for b16,,then slip the tech question in there I would get more repsonses
Old Sep 17, 2003 | 06:08 PM
speedworks's Avatar
could be an injector sticking. put the injector in another cylinder and see if the problem pops up there
Old Sep 17, 2003 | 06:20 PM
sporkcrx's Avatar
Default Re: hot start problem? (speedworks)
I'm just curious...did you have them cleaned?
Old Sep 17, 2003 | 06:47 PM
SiRkid's Avatar
Default Re: hot start problem? (sporkcrx)
yup, cleaned and flow tested
Old Sep 17, 2003 | 08:38 PM
hybridsol's Avatar
http://hondata.com/bb/viewtopic.php?t=67
No, it's just poeple don't like typing the same things over and over and over...
g2turbo
Engine Management and Tuning
Aug 20, 2013 05:16 AM
dserieskid
Sep 17, 2009 08:30 PM
solofthesouth
Apr 9, 2006 06:52 PM
GsTeg90
May 6, 2003 05:02 AM
