HELP!!! Engine still misfiring!!!
Old Sep 16, 2003 | 04:42 PM
one more chance's Avatar
Default HELP!!! Engine still misfiring!!!
Okay guys...
recently my B18C just underwent a turbo conversion consisting of a TD04L turbo, 3" exhaust, FMIC, larger injectors and the head was decompressed with a plate. Now, the engine is running a EMS stinger ECU. When it was time to get it tuned, it would start misfiring under boost! We've looked at all possibilities such as the spark plugs, changed the coils, played with fuel mixtures, even changed the ECU. The tuners are almost certain it is not an ignition problem, but an electrical problem. The other possible factor is the fuel pump, may have a look at that too! Can anyone else shed some light into this problem!!?? It's driving me bunkers!!!
Cheers!
Old Sep 16, 2003 | 05:59 PM
Default Re: HELP!!! Engine still misfiring!!! (one more chance)
help...anyone...
Old Sep 16, 2003 | 06:05 PM
Blown90hatcH's Avatar
What is your fuel pressure doing when you boost? What plugs? What gap? What boost levels? What coil/distr?
Old Sep 16, 2003 | 06:07 PM
speedworks's Avatar
Default Re: HELP!!! Engine still misfiring!!! (Blown90hatcH)
sounds like to large of a plug gap.
Old Sep 16, 2003 | 06:37 PM
TurboB18C1's Avatar
i recently had the same problem on the dyno with 16 psi, the problem was the gap on my plugs, so closeing the gap to a .24 of an inch fixed the problem, make sure that your gap is right, and what size injectors are you running on your car because my car misfires at idle because of 720cc but your misfiring under boost could be fuel delivery problem, does your new injectores require a resitor box??
Also are you running in closed loop or open loop under boost?
kitong
Nov 6, 2006 07:48 PM
tour de france turbo
Aug 27, 2003 01:40 PM
1dumbscreenname
Jul 17, 2003 01:15 PM
mattymatt
Jun 28, 2001 12:50 PM
