Best bang for the buck fuel management on ZC DOHC turbo 15-19 psi
I want to know if a S_AFC fuel management could be use for about 17 psi of boost on my ZC DOHC or a shoulk look in another way?
tks for your help
tks for your help
Re: Best bang for the buck fuel management on ZC DOHC turbo 15-19 psi (Garrett)
SDS will do it check it out http://www.sds-efi.com
Re: Best bang for the buck fuel management on ZC DOHC turbo 15-19 psi (90crxzc)
best bang for the buck you ask....
http://www.ghettodyne.com
its free my friend...if you are willing to learn a bit about the honda ECU, you should be set. Spend the rest of the money on a WB 02 and some dyno and street time and you will be golden! Although, it only supports the stock map sensor at current time...
for higher levels (15-19) get ZDYNE and the GM 3 Bar Map
