B20/ Vtec ??? how much boost can it handle ...
whats the most boost that a stock b20/ vtec can handle ? running either a b16 or b18c1 head stock cams .
also which turbo would be a nice set up for it ?
a friend of mine is considering going b20/ vtec turbo .
Re: B20/ Vtec ??? how much boost can it handle ... (Spoon1)
fmu setup i would say no more than 7-8 lbs, but people have preferences. I actually ran 6.5 with my b20 vtec I had no problems for 6 months, then the motor blew due to non boost related reason, What are his plans are far as fuel?
Re: B20/ Vtec ??? how much boost can it handle ... (quikB18B)
do you mean as far as injectors , fuel pump and ecu or management system ?
also what are some hp #'s on a set up like that ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon1 »</TD></TR><TR><TD CLASS="quote">do you mean as far as injectors , fuel pump and ecu or management system ?
also what are some hp #'s on a set up like that ..</TD></TR></TABLE>
Yes what injectors? standalone? ect....
Well i made 235/189 on 6.5 psi untuned with a messed fuel system
Tuned or **** even everything working correctly i dont see 250 whp on 7 psi a problem.
