Stand alone engine managment PLEASE HELP
Old Sep 17, 2003 | 04:56 PM
toolowsol's Avatar
Default Stand alone engine managment PLEASE HELP
B18C (jdm)
t25 turbo @ 7-10psi
DSM 450 injectors with honda resistor pack.
ignition retard .75 degrees/psi
vtec cross over 5200
skunk2 intake manifold
How do these tables look?????? I don't really know what i'm doing but I obviously have a program that i'm working with and these are what i've come up with. (I can supply graphs too if nec. I just want to make sure these values look close, (IE good enough for a basemap to use for a little bit so i can get a dyno run in and drive home.)
LOW CAM FUEL
HIGH CAM FUEL
LOW CAM TIMING
HIGH CAM TIMING
Old Sep 17, 2003 | 05:01 PM
grngsr01's Avatar
Default Re: Stand alone engine managment PLEASE HELP (toolowsol)
I don't know anything either. I am just learning. But I do like that data logger. Which one it is. Also, what ignition are you using.
Old Sep 17, 2003 | 05:13 PM
toolowsol's Avatar
Default Re: Stand alone engine managment PLEASE HELP (grngsr01)
its not datalogging, i'm trying to burn a chip for my motor, i'm making the program/rom now... stock honda ignition.
Old Sep 17, 2003 | 06:23 PM
johnisenglish's Avatar
Are you using Crome? If not the editior you are using looks just like it.
Anyway, you're most likely going to be running somewhat richer then will be ideal for safety and power, but for a base map the fuel setting look fine.
Your ignition maps are a tiny bit more advanced then I had my basemap set up (what rom are you basing them off?), but again, they should be absolutly fine for your setup, and you likely still have room to advance it slightly more after you 6.7psi colum.
Old Sep 17, 2003 | 06:27 PM
toolowsol's Avatar
Default Re: Stand alone engine managment PLEASE HELP (johnisenglish)
yes i'm using crome, thanks man, I appreciate your help
Jockobo
Oct 2, 2006 09:37 AM
PHiZ
Feb 24, 2004 07:27 PM
Civic_95_Si
Oct 24, 2002 01:09 PM
darrona
Jul 20, 2001 06:27 AM
