Fuel Pressure gauge.... regular vacume VS. Liquid filled
well i'm thinking about picking up a B&M fuel pressure regulator and a gauge that can be mounted in the engine bay. My question is this:
1) advantages or disadvanges of either of them?
2) which last longer?
3) how does each meter draw its source of vacume pressure?
On a side note...... with the B&M fpr, what is the cross point where i should get a Aeromotive instead of the B&M as in WHP application wise.
TIA
TIA
Re: Fuel Pressure gauge.... regular vacume VS. Liquid filled (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">well i'm thinking about picking up a B&M fuel pressure regulator and a gauge that can be mounted in the engine bay. My question is this:
TIA</TD></TR></TABLE>
imo . the liquid filled guages are more "steady" and accurate, i would figure that the liquid one would last longer due to the needle not bouncing around so much...
if you are getting a fuel pressure guage it doenst measure vacum, it woul measure fuel presure at the filter(if you are looking at the b&m setup)..... it simply bolts onto the fitting coming out of the fuel filter going toward the fuel rail.
B&M is only good for turning up pressure. not down. keep that in mind. or just get an AEM or better yet an aeromotive or sx.
b&m gauge is ok. my needle used to bounce alot but after a week it didnt move between more than 1/2 a psi. it's pretty steady now. liquid filled would mean less movement of needle from vibration and prob has the potential to last a lil longer.
Re: Fuel Pressure gauge.... regular vacume VS. Liquid filled (2.2Lcivic)
thanks for the info. What i am leaning towards is getting a B&M FPR and a liquid filled gauge.
I know that you can mount the REG gauge on the fuel filter or on the rail but how would you mount the liquid filled one? is it that much harder?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">I know that you can mount the REG gauge on the fuel filter or on the rail but how would you mount the liquid filled one? is it that much harder?</TD></TR></TABLE>
anyone wanna answer that question?
Re: (GSRswapandslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow »</TD></TR><TR><TD CLASS="quote">they mount the same way
they are sealed with the liquid inside is all</TD></TR></TABLE>
ok just so we are on the same page...
1) they mount on the same locations as would a regular gauge would (on top of the fuel filter or on the fuel rail)
2) same installation.
Re:
I'd go with the liquid filled (dampened) gauge hands down. The Marshal gauge pictured above can be bought for almost the same price as the B&M (non-dampened) gauge. The liquid filled gauge will make your fuel pressure adjustments easier.
I'm also using the Aeromotive type fpr, which I think is a great regulator. Aside from the more extensive means to mount it and plumb it into the fuel lines. I have used the B&M command flow before and didn't like it all to much. I would suggest the new rail mounted Aeromotive fpr. Very similar to the AEM fpr.
Re: Fuel Pressure gauge.... regular vacume VS. Liquid filled (Pengo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo »</TD></TR><TR><TD CLASS="quote">B&M is only good for turning up pressure. not down. keep that in mind. or just get an AEM or better yet an aeromotive or sx.</TD></TR></TABLE>
Sorry, not to jack your thread but I need to lower my fuel pressure after installing a bigger fuel pump on my jrsc setup and I just orered a b&m fpr-is there no way to lower the fuel psi with those? Which fpr's allow you to lower it?
Re: (Charlie Moua)
2) same installation.</TD></TR></TABLE>
They are only different because one is liquid filled and the other isn't. The B&M gauge came with a fitting to mount to the top of your fuel filter. If you bought that fitting seperately you could mount either gauge with it.
Re: (i2un)
I currently have both gauges on my set-up. Running in conjuction with each other. The needle on the B&M gauge bounces around more (looks like it vibrates +or minus by 1psi; But both the liquid filled gauge and the B&M show pretty much the same reading.
I've always liked using the liquid gauge. Looks better to me. But I've replaced it quite a few times because after a while the liquid would start to seep-out (not sure if it was from engine vibrations or high fuel pressures) and then I couldn't be sure that my readings were correct.
Re: (i2un)
thanks that some really helpful info guys. got any pix of your gauges..
Also you said you had to replace your liquid filled one.
-how often do you replace it? ... miles
-what psi are you normally at?...... i would imagin that PSI woud affect longativity or the meter ,... or not.
*your runinb both at the same time? if so how are you hooking them up and location where its mounted.
TIA guys
TIA guys
Re: (Charlie Moua)
Sorry for the late reply.
-I've replaced my liquid filled gauge about 4 times in 4 years...20k miles each year. I usually inspect it during oil changes to see if the liquid is seeping out and replace as needed.
-I've had fuel pressure as high as 100psi at times.
-I'm not certain if the longevity was affected by engine vibration, high psi or maybe even under hood temps. Could be a combination of all the above.
-When I first bought the liquid gauge years ago, my friend said he had a Brass Earls fitting for it; And stupid me didn't look at the fitting and I let him install it. T-fitting. (He cut the fuel line going from my rail to the fuel filter and placed it between the two. Didn't hurt anything but I would rather have not cut that line).
That's the only reason why I'm running both. I just keep it to plug the hole. Eventually I'll replace that line or buy another fitting to remove the gauge.
-It was interesting to me though to be able to compare the two gauges side by side. When and if the B&M gauge dies I'll probably replace it with the liquid gauge and just mount it atop the fuel filter with the B&M fitting.
-ps..I installed a AEM fuel rail awhile back. so I can add a third gauge to the mix...if I decided to be weird like that.
-pps..If you want I can snap a quick pic with my cheap digital cam and email it to you? Let me know.
Re: (i2un)
Also, B&M comes with an extra fitting (90 degree) that attaches to their other fitting. Then you can have the gauges face, tilted forward and upright....But when I had it like that, the hood wouldn't close.
Modified by i2un at 7:52 PM 9/24/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo »</TD></TR><TR><TD CLASS="quote">B&M is only good for turning up pressure. not down. keep that in mind. or just get an AEM or better yet an aeromotive or sx. </TD></TR></TABLE>
False. The B&M can adjust from 20-60psi of base fuel pressure. Until last week I had one on my car with a gauge, so this is verified. I removed it for ease of ecu tuning (one less variable).
P.S. I'd go with the liquid-filled if it isn't much more, since my regular one does bounce around alot...though, it's just a normal pressure gauge you can get at any welding/air-tool store for cheap!
Re: Fuel Pressure gauge.... regular vacume VS. Liquid filled (ion_four)
OT: but does anyone know what KIND of fluid is in that guage? cuz i have a marshall liquid filled, and i sorta pulled out the rubber stopper and i lost some of the fluid...its a little gooey, so i dont think its water
