Well I finally drove my Turbo'd SE-R!!
I recently about half way finished up my DET install on my 1992 SE-R. I drove it for the first time to work but didnt boost it up any. So I had to HeliCoil a bolt hole then I after I was finished I took it up the street or actually around the base and got into it a little. Needs an exhaust and needs to be tuned really bad also missing a few vacuum hoses but runs ok. Cant wait till it is completely done. Here is my current setup
1992 Sentra SE-R
Stock Bluebird SR20DET with Top Mount Intercooler
3" Downpipe with Electronic Cutout (in the making)
2.5" exhaust with Catco Converter and Magnaflow Muffler
Clutch Specialties Stage 2
Removed A/C
Removed Power Steering
Installed a manual steering rack from Sentra E
Removed all the interior sound deadening
ES Motor Mount Inserts
ES Suspension Bushing Kit
Apex SAFC
MSD 6AL
B&M Short Shifter
15x6.5 Kosei K1's
I also installed a Lawnmower Battery
I hope that I can get 12's out of this setup after I get a boost controller, get it tuned up and get some practice driving it. I have some slicks already so that is good. I dont know I guess the future holds the answer! Maybe I can post some pics soon.
1992 Sentra SE-R
Removed A/C
Apex SAFC
MSD 6AL
B&M Short Shifter
15x6.5 Kosei K1's
Re: Well I finally drove my Turbo'd SE-R!! (ringgold)
was removing the a/c and p/s necesssarry with the bluebird sr20det? I was to swap that inmy wife's 98 sentra se 4doo, but she ain't haven't it without her a/c, cause I've already lost it in my car.
Re: Well I finally drove my Turbo'd SE-R!! (slywfbpsi)
No you dont have to remove the A/C or the power steering to install a DET into a Sentra. I just did it to cut down on the weight and engine drag.
