Situations with Tial 35mm wastegate, and joe P MBC. please help!!!!!
ok, well, is it possible to run a lower boost level than the .45 bar spring?? i just got my car running, and want to push about 4-5 psi just to be safe for right now, to make sure everything is right. i tried driving it once, and the boost went to about 10 psi, so i wanna make sure. would i be better off just running the vacuum line right to the side of the tial, without the MBC? then it shoudl make .45 bar, right?? thanks
Re: Situations with Tial 35mm wastegate, and joe P MBC. please help!!!!! (Acura_I-RS)
You cannot run lower than .45 bar if that is what the spring is.
Yes, for the least amount of boost, skip out the MBC and run the vac line right into the side port of the wastegate.
Re: Situations with Tial 35mm wastegate, and joe P MBC. please help!!!!! (Poop111444)
u can also just drive the thing easy if u want less boost. once ur foot gets more sensitive and you get more used to the response of the boost gauge u can hold the boost where u want for daily driving. its just foot control
Re: Situations with Tial 35mm wastegate, and joe P MBC. please help!!!!! (Pengo)
take out your boost controller. You can buy a lower wastegate spring. I believe they make a 0.4 bar spring for you.
Re: Situations with Tial 35mm wastegate, and joe P MBC. please help!!!!! (R6Elmo)
well, i just ditched the mbc for now, and just running the .45 bar, and let me say it is ******* amazing, solid 6psi!!!! i keep blowing off one of my intercooler pipes, but i got a better clamp on it now. next i will have to get it tuned at elite in minneapolis!
