Calling all MAXREV OWNERS!!!
Old Sep 17, 2003 | 01:26 AM
JDEM1's Avatar
Default Calling all MAXREV OWNERS!!!
those of you guys running the maxrev kit, specifically the 99-00 Civic si guys... i have a question for you... i am running the maxrev kit with .57 trim 63 a/r t3t04e turbo and i was wondering.. HOW THE HELL did you guys manage piping and filter on the turbo?, theres a clutchline or tranny line in the way.. i have been running a mesh screen only... what have you guys done in your setups?..please help.. thanks in advance..
Old Sep 17, 2003 | 02:06 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Calling all MAXREV OWNERS!!! (JDEM1)
Send an IM here:
https://honda-tech.com/zero...01773
Old Sep 17, 2003 | 11:07 PM
red_sir's Avatar
I used a 3 inch 90 degree silicone elbow, 3 inch u bend, and then a filter. The silicone coupling goes onto the turbo, then the u bend connects to the coupling and hangs over the radiator hoses like the filters on the Greddy/Drag kits.
Old Sep 18, 2003 | 10:40 PM
JDEM1's Avatar
Default Re: Calling all MAXREV OWNERS!!! (red_sir)
but what about the cable in the way?, lets see some pics...
Old Sep 19, 2003 | 12:23 AM
red_sir's Avatar
Sorry I don't have a digi cam. But the cable doesn't get in the way. Although depending on how long the silicone coupling is, you might have to trim a little bit off the end that connects to the compressor.
Old Sep 19, 2003 | 01:48 AM
JDEM1's Avatar
how does it not get in the way?.. i dont understand... the cable/line is 1 inch directly next to the turbine wheel...
Old Sep 19, 2003 | 09:55 AM
krazy's Avatar
bend it away. i just bent the clutch hardlines back toward the tranny. it helps if u have a pusher fan IN FRONT of the radiator too..
krazy
Old Sep 19, 2003 | 04:01 PM
sneakypete's Avatar
Default Re: Calling all MAXREV OWNERS!!! (krazy)
Try mounting the turbo with the compressor side on the drivers side. But if you do this then you'll have to get your downpipe modified.
Old Sep 19, 2003 | 06:19 PM
CzanSOHC's Avatar
Default Re: Calling all MAXREV OWNERS!!! (sneakypete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakypete &raquo;</TD></TR><TR><TD CLASS="quote">Try mounting the turbo with the compressor side on the drivers side. But if you do this then you'll have to get your downpipe modified.</TD></TR></TABLE>
Thats what i did. You will lose P/S and have to make a new DP...I just fabricated my own 3" downpipe.
Old Sep 19, 2003 | 09:12 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: Calling all MAXREV OWNERS!!! (CzanSOHC)
just get a little creative. I had no real problems getting it to fit.
I don't have to go through the trouble of mounting the turbo in a whole new way, just get the pipe to angle up before it reaches the clutch line.
I don't know if one car might be different from the other SI, but I didn't have any problems getting it to fit at all.
Sorry I don't have pics of under it, it's not really easy to get the camera under that part.
Old Sep 19, 2003 | 09:14 PM
Snafu-Si's Avatar
Default Re: Calling all MAXREV OWNERS!!! (Snafu-Si)
Another thing of why mine might fit is I have a different size turbo, you said your is a 57 trim and a .63 a/r right?
Mine is a .60 Comp and .48 A/R. I don't know how much of a size difference on the outside there is if any.
Old Sep 20, 2003 | 01:31 AM
JDEM1's Avatar
i think my housing is a bit lower than yours so its directly next to the clutch hardline.. anyhow.. hopefully i can figure somethin, but i gotta shave more of the block to get clearance to fit a hose on there
Old Oct 2, 2003 | 09:01 PM
JDEM1's Avatar
back to top for more help.. i still dont have a filter
Old Oct 3, 2003 | 12:12 PM
JDEM1's Avatar
did i mention whoever can get it to work will get money
Jradrebel
Jan 12, 2005 05:28 PM
InLimbo87
Jul 11, 2004 02:31 PM
Mad Cow
Feb 10, 2004 08:52 PM
myflysi
Jul 22, 2003 08:41 AM
vtecsiqt
Jun 3, 2002 09:51 AM
