closed loop bov (searched)
Old Sep 17, 2003 | 10:12 AM
jazz215's Avatar
Default closed loop bov (searched)
in a closed loop bov setup, where does all the extra air go? also would you hear any pssshhhh sound? or would it just be muffled. also is there any benefits to having a closed loop setup? thanks
Old Sep 17, 2003 | 10:13 AM
mamaboy's Avatar
Default Re: closed loop bov (jazz215)
in a closed loop setup the released air from the BOV is recirculated into the compressor intake tract
Old Sep 17, 2003 | 10:28 AM
xci_ed6's Avatar
Default Re: closed loop bov (mamaboy)
The sound is muffled alot, but still audible. If it is closed loop it won't screw with the MAF sensor (if it is mounted before the turbo). I don't know if there is any other real benifits. maybe little things like reducing the drag on the compressor w/ BOV open since it won't have to suck air through the filter, and if the BOV is open at idle it will gget filtered air, but those two are not worth the reduction in sound IMO.
-Dustin
Old Sep 17, 2003 | 11:01 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: closed loop bov (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">The sound is muffled alot, but still audible. If it is closed loop it won't screw with the MAF sensor (if it is mounted before the turbo). I don't know if there is any other real benifits. maybe little things like reducing the drag on the compressor w/ BOV open since it won't have to suck air through the filter, and if the BOV is open at idle it will gget filtered air, but those two are not worth the reduction in sound IMO.
-Dustin</TD></TR></TABLE>
also, with the pressurized air being released through the bov into the inlet of the turbine wheel it helps to keep the turbo spooled between shifts instead of slowing down...the released intake air acts as "supplimental exhaust gas"...just on the other wheel of the two
Old Sep 17, 2003 | 11:15 AM
jazz215's Avatar
kool thanks, ill try the closed loop setup for a while.
Old Sep 17, 2003 | 11:51 AM
gritsak's Avatar
Default Re: (jazz215)
theres no real reason to run close loop on a honda since they are map...the whole reason some cars run closed loop is so it doesnt mess with the amount of air metered by the maf and how much is actually in the system..when you vent a maf car bov it will cause it to run rich when the bov opens...but on a map car it doesnt make a difference
the only other benifit would be it doesnt blow an dirty air around the engine bay but just put a mini filter on the end of the bov and that fixes that
Old Sep 17, 2003 | 12:56 PM
jazz215's Avatar
Default Re: (gritsak)
i just wanted to run the closed setup so it will muffle the sound, i want it as quiet as possible. unless theres a better way?
Old Sep 17, 2003 | 06:42 PM
Bailhatch's Avatar
What about a muffler off of a lawnmower or having it dump into a can of wool or something with baffles? As long as it didn't suck in anything at idle. i just gave up cuse i want as little extra stuff on my motor.
jsbayer
Jul 27, 2009 06:29 PM
1FastCoupe
Aug 18, 2005 07:59 PM
ZhaGg
Jul 1, 2004 04:53 PM
Heath
Nov 21, 2002 03:25 PM
CM-R
Jul 27, 2002 09:12 AM
