2 boost settings. Hondata users.
Old Sep 17, 2003 | 02:57 PM
5thgencivic's Avatar
Default 2 boost settings. Hondata users.
I was wondering how many use 2 boost settings with their hondata setup? Example would be using the greddy profec b. Say first setting is 8psi(for first gear), second is 12 psi. Is it possible with hondata? Do most of you tune for the higher boost setting, then just run rich when on the lower? Trying to figure out actually how rich it would run and if it's worth it. any input is appreciated. Thanks.
Nate
Old Sep 17, 2003 | 03:00 PM
Spunkster's Avatar
Default Re: 2 boost settings. Hondata users. (5thgencivic)
Your tuner can first tune at the lower boost level and then the higher boost level. Ten you maps will be tuned for both. Download the demo software from http://www.hondata.com and you will see how this is very simply done.
Old Sep 17, 2003 | 03:08 PM
Default Re: 2 boost settings. Hondata users. (Spunkster)
But will the maps crossover when the boost setting is changed? I'll check out the demo. thanks.
Old Sep 17, 2003 | 06:41 PM
platinum00's Avatar
just tune for the high boost setting and then turn the boost down.
platinum.
ochocinco
Engine Management and Tuning
Apr 8, 2010 12:44 PM
HondAcura
Northeast (Sales)
Jul 14, 2006 03:37 AM
BLWNB16A@11psi
Jun 22, 2005 08:27 PM
btrim23
Feb 26, 2005 02:32 PM
BlackThorN
Dec 21, 2003 12:51 AM
