running rich, affect water temp. ?
at the jetties fishin'
Re: running rich, affect water temp. ? (r7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r7 »</TD></TR><TR><TD CLASS="quote">would running real rich cause the water temperature to be very low?</TD></TR></TABLE>
yes and no.
It'll keep you from overheating like you would if you were running too lean but it doesn't really have a cooling effect per say. Running real rich will just give you a shitload of carbon buildup, foul out your plugs early, and take out your converter long before it's time.
oh yeah, and make pretty black clouds behind you
yes and no.
Re: running rich, affect water temp. ? (stackz)
hmm, maybe its a bad thermostat than.. the temp gauge on the cluster is just above the C (lowest mark)
*hopefully* going to get tuned friday.. . and i ordered a new thermostat.. .
edit - when the temp is this low, is it damaging to drive? and also, when i try and boost it stutters badly
a honda just doesnt run the same when its cold, no vehicle does, especially one with vtec. I wouldnt drive it hard if its running that cold.. I'm not even sure if its possible for it to run that cold to be honest. Maybe your getting a faulty reading.
