Identify My Turbo....
Old Sep 16, 2003 | 09:26 PM
Unsung's Avatar
Default Identify My Turbo....
Hey guys. I won this turbo on ebay: http://cgi.ebay.com/ebaymotors...=6755
And this is what I got in the mail. Not the same thing... What did I get?
I'm a turbo noob, so go easy on me Thanks in advance.
Old Sep 16, 2003 | 09:27 PM
SiBirdie's Avatar
Default Re: Identify My Turbo.... (Unsung EM1)
dang that's a small *** turbo bro! lolz.. I say its a T25
Old Sep 16, 2003 | 09:30 PM
Unsung's Avatar
Default Re: Identify My Turbo.... (SiBirdie)
It's way bigger than t25
Old Sep 16, 2003 | 09:33 PM
Full-Race Henry's Avatar
id be pissed if i were you since they didnt send you the right turbo
Old Sep 16, 2003 | 09:41 PM
Ri5e's Avatar
Default Re: Identify My Turbo.... (EF8_Fan)
Looks like a T3 off of a 300ZX
Old Sep 16, 2003 | 09:43 PM
Unsung's Avatar
Default Re: Identify My Turbo.... (Tein Man)
are they still .60/.48? would it work the same as the one I originally ordered? I can't find the intake housing AR, the exhaust is clearly labeled in one of the pics.
Old Sep 17, 2003 | 12:40 AM
Unsung's Avatar
Bump... need some more opinions. This is going on a b16a with LoveFab SST manifold... Too small? Eventually I'm building a bottom end and upgrading the turbo, but for now I'm only looking for 220-250whp.
Old Sep 17, 2003 | 01:15 AM
egturbo's Avatar
hmm the one on ebay is a airresearch.. but the turbo looks pretty new though. i say its a t3
Old Sep 17, 2003 | 08:04 AM
hulkhb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tein Man &raquo;</TD></TR><TR><TD CLASS="quote">Looks like a T3 off of a 300ZX</TD></TR></TABLE>
thats my guess also. that suxs man it said .60/.48 in the auction.
Old Sep 17, 2003 | 08:11 AM
illi Adik's Avatar
Default Re: Identify My Turbo.... (hulkhb)
T3, super 60's were upgrades for for the mid 80's shelby dodge's. I hope it will work for your set up the way hondas are set up, could be backwards.
Old Sep 17, 2003 | 08:17 AM
integra-modder's Avatar
Default Re: Identify My Turbo.... (Jackson4Door)
Thats some shady ****...
You can obviously tell by comparing the wastegae housing to the turbo in both pics...
Old Sep 17, 2003 | 08:21 AM
T4eg's Avatar
the turbo you posted and the turbo on ebay are different turbos. Ebay is airreseach and one you got says nissan where ebay one says airresearch.
Old Sep 17, 2003 | 08:22 AM
FuzzyGreen's Avatar
I don't know if that is a T3, it looks smaller then my T3 with its tiny.42 AR.
Old Sep 17, 2003 | 08:24 AM
92HB_HB's Avatar
Default Re: Identify My Turbo.... (FuzzyGreen)
one thing's for sure.. you'll spool pretty quick , but will lack top end .. if i was you, I would demand a refund and complain since the product was misrepresented.... i would also get a t3t4 if you're looking for decent power from the getgo..
Old Sep 17, 2003 | 08:37 AM
pagong's Avatar
Finally going to turbo that car huh? Cant keep away from the darkside..good luck!
Old Sep 17, 2003 | 08:54 AM
omahaturbocivic's Avatar
Yup that compressor looks like its off of an 85 or 86 300zx and it is .60 ar. I am running that same turbo as well. Yours however does not have the proprietary nissan 5 bolt exhaust housing that was a pain is the *** to work with. Should be a decent t3.
Old Sep 17, 2003 | 09:28 AM
LoSt is BlaCk's Avatar
i second!
Old Sep 17, 2003 | 10:15 AM
Unsung's Avatar
Default Re: Identify My Turbo.... (Chpt1onBOOST)
Thanks for your help guys. I'm going to try and get my money back, but I doubt the guy will respond, so I may have to relist it on Ebay....
Old Sep 17, 2003 | 10:33 AM
tegasaurus's Avatar
it does look smaller than a t3...
my guess is its the T25 ball bearing from an sr20det
or the 300zx t3
its not that bad of a turbo... you'll have more torque than HP probably (always something to brag about with a honda )
-Ryan
Old Sep 17, 2003 | 11:20 AM
zojirushi's Avatar
Default Re: Identify My Turbo.... (tegasaurus)
That is a T3 off a Nissan z31. its .63 turbine side. Its really not bad at all. I had it on my turbo auto integra and ran a best of 14.6 on it with a really shitty s-afc hack tune. The original turbine side on the turbo won't fit most t3 downpipe flanges. However, judging from the picture, it seems as if the previous owner has already changed the turbine side to the more standard t3. I had to do the same as well.
Edit: on second thought, it might not be a t3 off the nissan. I noticed that this is not water cooled. The turbo off the nissan is in fact water cooled. This may be a different turbo with just the nissan compressor side on.
Old Sep 17, 2003 | 12:36 PM
reaction360's Avatar
Default Re: Identify My Turbo.... (zojirushi)
that sucks man, death to all scammers
Old Sep 17, 2003 | 12:46 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: Identify My Turbo.... (reaction360)
probably he sells them in bulk and uses that auction picture as a "file photo"
irregardless of it saying airresearch or garrett or nissan on it, it's still a garrett T3 that much is certain. Being that it looks identical to the two 300zx "upgrade" T3's I've come across in the past it's exactly as described in the auction...
.48/.60 trim garrett T3, which is what you bid on. If you want to be a stickler about what it reads on the compressor housing then by all means send it to me and I'll gladly take it
It will run just fine on your car man, enjoy it and have fun. Probably the reason it says nissan on it is due to the guy's wholesaler might use nissan cores one month, saab cores the next, svo mustang cores the next...I only say this because the one in the auction picture has the compressor housing off a saab, while the T3 off an svo will say GARRETT across it.
Old Sep 17, 2003 | 01:34 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Identify My Turbo.... (stackz)
its the same turbo as int he picture just the housing is branded differtly. i would say it is the same spec as what the listing say. it looks identical to me.
Old Sep 17, 2003 | 01:37 PM
01ITR#700's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">probably he sells them in bulk and uses that auction picture as a "file photo"
It will run just fine on your car man, enjoy it and have fun. Probably the reason it says nissan on it is due to the guy's wholesaler might use nissan cores one month, saab cores the next, svo mustang cores the next...I only say this because the one in the auction picture has the compressor housing off a saab, while the T3 off an svo will say GARRETT across it.</TD></TR></TABLE>
I agree, just keep the turbo...I'm no turbo professional or anything but it appears as though you technically got what you ordered(or won in this case)
HTH
Mark
Old Sep 17, 2003 | 02:24 PM
SiRkid's Avatar
Default Re: Identify My Turbo.... (01ITR#700)
nissan t28?
