Increasing Stroke?
Old Sep 16, 2003 | 08:10 PM
Project_SOHC_EX's Avatar
Default Increasing Stroke?
For any of you that might know. What does increasing the stroke from say 87mm in a B18a1 to 92mm do in terms of performance?
Old Sep 18, 2003 | 10:46 AM
Default Re: Increasing Stroke? (Project_SOHC_EX)
Is anyone going to respond?????????????? Please I'm in need of some serious opinions here
Old Sep 18, 2003 | 10:49 AM
FuzzyGreen's Avatar
Well it will lower your rev limit due to piston speed but will give you more torque and power throughout the lower and mid rpm ranges. Performance might decrease in the higher rpms.
Old Sep 18, 2003 | 11:04 AM
DIRep972's Avatar
Smarter than you
why would u want to do that? If you had a longer stroke crank w/ a longer rod/deckplate you could maintain your rod/stroke ratio and increase the displacement at the same time........ but! its really not nessacary on a turbo car. Stock GSR/LS crank is all you need for 1000whp w/ the right turbo set up.
Old Sep 18, 2003 | 11:07 AM
Mr. Softee's Avatar
Default Re: Increasing Stroke? (DIRep972)
most likely changing your stroke or bottom end geometry is going to be overcomplex and a waste of money.
Old Sep 18, 2003 | 11:09 AM
DIRep972's Avatar
Smarter than you
Default Re: Increasing Stroke? (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">most likely changing your stroke or bottom end geometry is going to be overcomplex and a waste of money. </TD></TR></TABLE>
WERD!
Old Sep 18, 2003 | 11:14 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">
WERD! </TD></TR></TABLE>
that's to much for me to think about. I don't get paid to have a fast car. I pay people!
Old Sep 18, 2003 | 11:21 AM
pornstarSR's Avatar
by increasing stroke you change a few things...
rev range changes to lower, even though you can rev it to 9000 but the pistons speed is gona be pretty high...
also you need a custom rod if your not gona deckplate
but all in all the idea of increasing stroke gains you torque for the jist of it
http://www.crower.com/cat/impo...shtml check this out
the only thing is i havent presonally had any experience with crowers stroker stuff...
the liters is what its all about too, displacement.....more displacement more power
its complicated, lots of things change when you stroke a honda
Old Sep 18, 2003 | 11:23 AM
Mr. Softee's Avatar
Default Re: Increasing Stroke? (pornstarSR)
or you could spend all that money on sleeves and a better fuel system and turbo and just up the boost and make a ton more power.
Old Sep 18, 2003 | 11:25 AM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">or you could spend all that money on sleeves and a better fuel system and turbo and just up the boost and make a ton more power.</TD></TR></TABLE>
EXACTLY!
Old Sep 18, 2003 | 11:34 AM
pornstarSR's Avatar
yeah getting a custom crank is not cheap...
turbos are the great honda replacement for displacement
Old Sep 18, 2003 | 11:47 AM
FuzzyGreen's Avatar
Take it from someone that owns the longest factory stroked B series, IT'S NOT WORTH IT. 95 mm stroke and only about 10 lbs/ft more torque then a B18a/b. This thing runs out of air after 6k rpms.
Old Sep 18, 2003 | 11:57 AM
Muckman's Avatar
Moderator in Chief
They want to charge $1500 extra for a billet crank over the forged crank! Is it just me or is that insane?
Also note it says wait 4-6 months for the crank lol
Id have to agree with everyone above, it seems like alot of money for little gain. Just boost more and all is well. If you want a longer stroke, you shoulda went with a domestic, not a honda.
Old Sep 18, 2003 | 12:18 PM
Thank you all who participated in my discussion topic. This is one of the few times where I have gotten all negative responses to one of my turbo ideas. The idea of my motor running out of breath at 6k wouldn't be too good for a turbocharged application. Thanks fellas, I really appreciate the comments and info.
Old Sep 18, 2003 | 01:16 PM
Mr. Softee's Avatar
theres no way the car will run out of breath at 6k with an LS crank. that is an issue with your tuning or head... therse tons of ls/vtecs making power over 8500
Old Sep 18, 2003 | 01:25 PM
FuzzyGreen do you care to comment on this individuals statement?
Old Sep 18, 2003 | 01:36 PM
DIRep972's Avatar
Smarter than you
guys he is talking about his prelude. hence 95mm stroke.
Old Sep 18, 2003 | 01:44 PM
FuzzyGreen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project_SOHC_EX &raquo;</TD></TR><TR><TD CLASS="quote">FuzzyGreen do you care to comment on this individuals statement?
Well he somewhat has a point, it's very possible my engine's head or intake manifold is restrictive, but even with 5psi boost it looses power above ~6500 rpms, which should show that it isn't all about breathing.
Besides an LS/VTEC still has a WAY shorter stroke then 95mm. I have owned a B18b and a ZC and they pulled WAY better on the top end then my B21. Modified or not.
There is a reason Honda went with a shorter stroke on the vtec motors. Piston speed and high rpm breathing. At a high rpm you cannot fill the long stroke cylinders whereas a short fat cylinder (F1/motorcycle engines) will have plenty of time. The opposite it true at low rpms where the long stroke sucks in way more air cause it has time to pull it in.
Old Sep 18, 2003 | 01:54 PM
Mr. Softee's Avatar
Default Re: Increasing Stroke? (FuzzyGreen)
ahh i didnt know you meant the old prelude crank. i was thinking b18b/a crank.
im sure that does drop off a little as piston speeds are extremely high at high RPM. Still at 5psi most turbos are going to run out of breath above 7k anyway.
Old Sep 18, 2003 | 05:02 PM
Quick 200k Mile Motor's Avatar
most of us already know that increasing the stroke shifts the VE down (earlier torque production and compromises the highend),
but something else might want to consider: Traction.
In a FWD, it's more suitable having a motor with most of the power in the mid to upper rpm range instead of down low.
It would be impractical for most power to be applied at low rpms (unless you like burn-outs) .
c5stunna
28
Feb 12, 2009 11:12 AM
b16vtecsol
Apr 6, 2004 06:39 PM
khcivic
Jan 28, 2003 09:25 PM
allmotorhonda
Dec 21, 2002 05:27 PM
Spade
Nov 8, 2001 08:15 PM
