new turbo
new turbo
well my turbo is smoking more than snoop dogg and is leaking oil. i decided against getting a rebuild because i was not really happy with how it was performing. its a t3 off of an auto tbird. 0.60 AR compressor, 0.48 AR turbine housing. i called up cheap turbo and they suggested a t3to4e .60ar compressor, 57trim .48 ar trubine stage 3 wheel, for my setup.
daily driven integra
jdm b18b
drag manifold and down pipe
2.5 kteller exhaust
afc hack to be tunned around 8-11 psi.
i know that t3t04 will push more air but the turbo isn't actually any bigger than the one i have know. why will it not fall of up top like the t3. also what does a stage 3 wheel mean.i also searched on the difference between the t3/to4and found out that the e series has 6 blades and the b has 7-8 but what does that mean? what do you get out of having less/more fins? also if you have any suggestion on different turbos i could possible use, let me know.
Modified by arjusmc at 1:01 AM 9/16/2003
jdm b18b
2.5 kteller exhaust
Re: new turbo (TotalBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TotalBoost »</TD></TR><TR><TD CLASS="quote">How big is your budget? If you really want something good, get a ballbearing one!
Andre</TD></TR></TABLE>
Dual Ball Bearing even
1 Post
explain this ball bearing and dual ball bearing to me. i am new to this concept. how much are they usualy? who sells them and how much? what are the benefits of having one? thnks yo.
