Code 13 on VAFC Hack???
Old Sep 16, 2003 | 12:24 PM
VanHonda's Avatar
Default Code 13 on VAFC Hack???
The first night I ran at the track on the afc hack, about my 3rd run, the cel came on and it was code 13, Barometric pressure sensor circuit. Is this problem just a result of using the hack or is there more too it. I was running about 5 lbs of boost when it happened and it has never gone away since. If I reset the ecu, it will eventually come back on a few miles down the road.
Old Sep 16, 2003 | 12:26 PM
boosted hybrid's Avatar
Default Re: Code 13 on VAFC Hack??? (VanHonda)
When i had this code a few years back the barometic pressure sensor on the chip board was damaged, I eventually had to find another ecu.
Old Sep 16, 2003 | 12:40 PM
VanHonda's Avatar
Default Re: Code 13 on VAFC Hack??? (boosted hybrid)
would this just be a coincidence that it happened the same time I started to use the hack? the ecu is in a 2000 civic Si. I wouldnt think this should be a problem
Old Sep 17, 2003 | 08:10 AM
99blusi's Avatar
I got the same code the other day on my 99 Si, but on the Greddy Blue box. Shouldn't cause any problems, just reset your computer and you should be good.
Old Sep 17, 2003 | 07:46 PM
scttydb411's Avatar
baro sensor won't affect anything it just goes on since the map voltage is different than the baro sensor. just periodically check your code to make sure that's the only one you have. mines on all the time for baro sensor.
Old Sep 17, 2003 | 07:47 PM
Sinner's Avatar
could be... your running to rich. happens to me when I over fuel my motor.
Old Sep 17, 2003 | 07:49 PM
VanHonda's Avatar
Default Re: (Sinner)
I know for a fact that the car is running to rich...I am waiting on a few things before I tune the car, so its just overly rich on the hack. I also have the code 45 for system to lean/rich.
Thanks for the help,
Craig
Old Sep 17, 2003 | 07:50 PM
Sinner's Avatar
just turn down the fuel... a tad bit and retry.
Old Sep 18, 2003 | 02:56 AM
VanHonda's Avatar
I have messed around with the fuel a little here and there, but i have it set at -41 for idle then about -43 or -44 the rest of the way. The car backfires a little from being rich, but if i lean it out anymore the car has a tough time idleing????
Is this normal?
Old Sep 18, 2003 | 03:15 AM
rjardy's Avatar
Default Re: (VanHonda)
13 is pretty common with the hack on obd2 cars. to get rid of it, go obd 1 or standalone. You should be able to play with your setting to keep it from coming on allso.
Rob
Old Sep 18, 2003 | 06:15 AM
VTC_CiViC's Avatar
Default Re: (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">13 is pretty common with the hack on obd2 cars. b</TD></TR></TABLE>
Yep. I had it also
Old Sep 18, 2003 | 09:02 AM
inspyral's Avatar
You're throwing a baro sensor code because the hack is cutting your MAP signal. When the ECU compares the pressure the baro sensor is seeing to what the MAP senor says is atmospheric, it sees a large discrepancy and thinks something is wrong with the baro sensor.
silverboost
Sep 28, 2005 02:30 PM
SOHCex20
Aug 18, 2005 08:49 AM
cjames235
May 10, 2005 12:52 PM
ILLICON3000
Aug 4, 2004 03:25 PM
Iceman05
Apr 13, 2004 04:38 AM
