how much boost?
Old Sep 17, 2003 | 10:40 AM
civictun's Avatar
Default how much boost?
I just have to get a downpipe and intercooler pipes made before I get my car tuned. I was interested to see about how much boost I can run before I go dyno the car. The engine setup is
GSR block GE 84mm sleeves
Je pistons 10:1
eagle rods
ferrea valve train, ported head
1000cc injectors
full-race manifold
T4 60-1 ball bearing turbo
116 race gas
Hondata
I'm hoping to run over 20lbs more like 28lbs. Does this sound doable.
David
Old Sep 17, 2003 | 10:48 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: how much boost? (civictun)
yes it's do able. You can see great power out of that. Over 500whp. If you go through with it I would like to see you race a civic that is local here. Or hes online. hondahvn. Me and him were out last night and he pulled a hayabusa.
Old Sep 17, 2003 | 11:36 AM
civictun's Avatar
Default Re: how much boost? (HybridcivicLS-T)
That would be fun to beat a bike especially a Hayabusa
Old Sep 17, 2003 | 02:56 PM
Double121's Avatar
Yeah racing a hayabusa would be cool until you realize his turbo is bigger than yours. There are way too many people going FI on those things.
Old Sep 17, 2003 | 03:01 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: how much boost? (Double121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Double121 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah racing a hayabusa would be cool until you realize his turbo is bigger than yours. There are way too many people going FI on those things.</TD></TR></TABLE>
Well i was talking about the N/A Only one turboed are after market set up.
Old Sep 17, 2003 | 03:38 PM
grndcont's Avatar
i hope you arnt thinking of runing any boost untill it is tuned! (i.e. dyno)
Old Sep 17, 2003 | 03:55 PM
civictun's Avatar
I am towing it to the muffler shop to get the pipes bent for the intercooler and downpipe. After getting it back home I was planning on cranking it up and making sure there are no leaks and everything checks out then towing it to the dyno. Definately don't won't to take a chance on blowing the engine. I broke the engine in while I was getting the rest of the parts I needed for the turbo install.
I was thinking of telling them to tune it with as much boost as possible. I will probably only run 12-15lbs on the street and 25-28lbs at the track at least that is what I am hoping for.
Old Sep 17, 2003 | 04:07 PM
grndcont's Avatar
on 10:1 i might want to limit it to 25psi. are u on the stock ignition? ive seen missfires at 18 psi and up.
Old Sep 18, 2003 | 02:10 PM
civictun's Avatar
Default Re: (grndcont)
I'm running MSD 6AL with external coil.
Old Sep 18, 2003 | 02:40 PM
anothaRRR's Avatar
Default Re: (civictun)
Yo David, glad to hear you are pretty close to getting your car done. Im sure it will be a beast. Hopefully everything goes well. Im practically done with mine. Good luck man. I would limit the boost to like 25 psi.
turbotime
Aug 15, 2004 10:44 PM
ForgedSleeper
Mar 21, 2004 07:45 PM
1SlowSi
Dec 28, 2003 11:17 AM
xrtdac
Oct 27, 2003 12:57 PM
Quiklude
May 26, 2003 10:26 PM
